Question about "The Legend"
Hi everybody,
I've bought "The Legend" by Aeon Soul .. which is a really great product by the way. But there is a little flaw ... ahve a look at this image:
(just in case ... I've attached the image as a file)
As you can see, the leather underlayer is on the right leg above the boots and on the left leg, there's a hove poke through of the boots through the underlayer. I've tried to fit it, but there's no chance with the provided morphs.
Did anyone encountered the same problem?
Is there a solution for this?
It's not a really big problem ... but it's anoying ...
That looks like smoothing is trying to smooth the pants over the boot on the right leg. Check the pants and make sure the smoothing target is G8F, not the boots. If that's not it, I can check on mine at home tonight.
I just took a quick look and when I load the pants and boots both left and right are covered by the pants at the top.Make sure you have GF selected when loading each item. For me booth pants and both boots have GF8 selected for smoothing.
Thanks for he comments ...
It's a G3F on my side. I tested again ... loaded a fresh standard G3F without any further morphs. Loaded pants and boots with G3F selected. Same result.
Checked mesh smoothing ... collision item is always G3F.
