Can't run the software
I've installed the software and all the plugin-things that came with the DAZ install manager, but after I ran the it, the program pops up but stops responding and crashes.
My PC is completely new, maybe there's some kind of driver needed?
  • Does it literally crash or does it just sit there? What are your system specifications, and what security software are you using?
  • What is your operating system and PC specs, e.g. video card, RAM?
    When it crash, do you get a crash window which can tell you why?
  • Also, was this the first time you installed DAZ Studio?
  • 12971935041297193504 Posts: 10
    edited August 2019
    System:Windows 10 Pro
    CPU:Threadripper 2970WX
    RAM:64GB
    GPU: 2x 2080tis w/ SLI enabled
    It does not, it just says that it stoped responding.
    Yes, it was.
    Post edited by 1297193504 on
    It sits there at first, but if I click anywhere on the program it stops responding and turns white , after clicking a few times it crashes
  • DoctorJellybeanDoctorJellybean Posts: 10,248
    edited August 2019
    RAM:64GB
    Yes, it was.
    Try disabling SLI and launch DS again. And make sure the NVIDIA drivers are up to date.
    Post edited by DoctorJellybean on
  • The problem is fixed! It is because of my old GPU driver (like a week old), thanks DoctorJellybean for helping
    Another way to solve, simply drag the window to your primary monitor, I had it on my secondary one. A lot of software tend to have this issue (Cura for example).
