Need help with Legacy UV for Genesis 8 to Genesis 2 males, Michael 5
Hello, I am coming back to Daz3D from a long period of absence. I got the Legacy UV for Genesis 8 in order to use some existing mats I bought for M5. I can't seem to get it done properly since the nostrils are in a weird place and the lips look wrong. Am I doing this right? The Readme file isn't helping.
Can someone walk me through this as if I am 6-years old?
  • You need to:
    1. Click on the '!Prepare Genesis 8 Male' icon;
    2. Apply the M5 MAT (which must be in .duf format);
    3  Click on the 'Apply Michael 5 UVs' script icon.
    These icons are found in 'People: Genesis 8 Male: Anatomy: Legacy UVs' in the Content Library tab.
    The User Guide, which explains the process in greater detail, can be found at:
    http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/47051/47051_legacy-uvs-for-genesis-8-genesis-2-male-michael-5-michael-6-user-guide.pdf
    I hope this helps.
  • No it doesn't. I follow the three steps, made sure that the mat is in .duf format. The nostrils and lips still look weird. Is it because it's a David 5 mat?
  • LeanaLeana Posts: 12,811
    David 5 has its own UVs, so yes, that would be the reason it’s not working perfectly.
    You can use the Map Transfer feature to convert it from D5 to M5 UVs.
  • As Leana says, David 5 has different UVs to Michael 5, so the M5 UV Set will not work for a David 5 texture.  I did do a UV conversion of David 5 for Genesis 3, but have not done one for Genesis 8.
    To convert the David 5 texture to a Michael 5 texture using the Map Transfer utility in DAZ Studio, a good tutorial to use is the following:
    https://www.daz3d.com/forums/discussion/95701/tutorial-converting-custom-genesis-2-uvs-to-genesis-3
    This tutorial specifically relates to Genesis 2 UVs, but the principle is the same for all generations.
  • Thanks for the response. I might try the map transfer one day but since I do not know my way around Daz enough for that sort of stuff, I'll probably let that one go until something new is developed. Thank you!
