Manuel Download Question
dash2128
I need to manually downoad a new product, and wanted to know the precise path and folder I should place it in, so that that it will run properly.
What would that be?
Do you use the default content directories in DS? And what OS do you use?
I think I use the default.
Windows
Thank you for replying!
By default DS uses the following content folders on windows systems:
To install content manually is rather simple:
Thank you for the clear instruction,
That should help!
I couldn’t find a Manuel in the store, but Diego 8 was just released today. Hope that helps.
