effects tab issue
Anyone else et a lagginess when you go into the effects tab of a figure? Speeds up when i manage to get out of that tab
  • 3drendero3drendero Posts: 2,029
    May be a random plugin issue. Try un installing some plugins.
    a figure in particular?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,522
    Always lags on hair effects
  • VIArtsVIArts Posts: 1,529
    Wow, i wasn't notified of responses...
    it's laggy with any figure,.
    i'll try yoinking pluggies
    Open Carrara.
    Load a figure.
    Select "Actor".
    Go to Effects tab. Do sojmethng, like simply enable Aura or collapse a section.
    Lag! Close Carrara.
    Delete one plugin.
    Repeat entire process.
    I deleted the only added plugins in my effects tab -- Cognito, Wireframe pro, Toon pro -- without reinstalling them. No luck
  • I actually doubt it's the plugins, it's always done it for me, just one of those things
    I just did a fresh reistall and that didn't help ether, so...
    it could be the scene preview which is the lag after changing effects
    try lowering the settings in ipr, like, turn off transparency,
    try change the texturing from full texturtes to the ball to the left of it.
    in the whatnow? lol
  • StezzaStezza Posts: 8,882
    very strange.. I haven't had any issues at all with this problem... so I'm no help surprise
    fun!
    i never went into edit blur before
    interactive shader setting can affect speed of preview window.
    interactive settings will affect preview speed.  doesn't affect the render, just the preview window
    731 x 631 - 102K
    985 x 529 - 125K
    905 x 558 - 90K
    1137 x 535 - 106K
  • PGrePGre Posts: 95
    I just started having an issue with lag each time I open the UV mapper in the Vertex Modeller. Have only been able to solve it by switching the interactive renderer from OpenGL to software or vice versa. It doesn't matter what I switch to, or if I switch back right away, just that I make a switch. Never had that issue before this week.
    P
    did your video driver update?
    Misty, how do i rfind that interactve render dialog?
    Hi
    theres a hard to see red arrow pointing to the icon  top right of preview window, it's an up arrow
  • Bunyip02Bunyip02 Posts: 9,291
    Mystarra said:
    Hi
    MAJourney, if you are colourblind for the colour red let us know and someone will redo the red bits in a different colour.
    it was hard to see against the background but i see it. thanks misty and bunyip
    well, that didnt work either
