ShareCG G8M barbarian - can someone try to download this?
DiomedeDiomede Posts: 11,294
edited August 2019 in Carrara Discussion
EDIT
Barbarian Outfit Untextured for Misty's G8M - In DUF format - you will have to convert fiugue rigging to blended weight (save as support asset) to use in Carrara, and best if you apply some textures
https://sharecg.com/v/94316/view/21/DAZ-Studio/G8M-Barbarian-FRD01-Untextured
Post edited by Diomede on
  • WendyLuvsCatzWendyLuvsCatz Posts: 27,887
    downloaded but not sure when I can try it as my PC tied up doing stuff
  • DiomedeDiomede Posts: 11,294
    Has anyone tried it yet?
    Is there a data error when conforming the pants?
  • Bunyip02Bunyip02 Posts: 4,277
    edited August 2019
    Error with the pants, all other items loaded okay.
    2802 x 1044 - 444K
    2777 x 1037 - 431K
    Post edited by Bunyip02 on
    edited August 2019
    Checked that software that they have to give away as well.
    2429 x 1037 - 415K
    OK Thanks - will investigate
    edited August 2019
    yes you have people nested in a content folder and it needs clothing folder under Genesis 8 Male
    I will drill down and see if the pants are also misplaced in a folder when I get time if you haven't fixed it
    1928 x 1048 - 193K
    edited August 2019
    yes his dacks have gone awol from Data
    1004 x 355 - 59K
    Thanks
  • MystiarraMystiarra Posts: 35,458
    the runtime and data folder go inside the content folder. smiley
    533 x 263 - 23K
    edited August 2019
    Could someone check again please?
    Doh, just saw your post, Misty.  I just posted an update that should address the pants dsf as per Wendy.
    https://sharecg.com/v/94314/view/21/DAZ-Studio/G8M-Barbarian-Untextured-Update
    dufs are in the right place.
    the dsfs and textures won't be found unless the data and runtime folders are inside the content folder.
    edited August 2019
    Another Update!!
    Could someone download and try the outfit now?
    I started over.  Pants dsf should be in the data file.  The data and runtime should be in the content folder.  The outfit is in People \ Genesis 8 Male \ Clothing \ Diomede
    Fingers crossed
    Barbarian Outfit Yet Again
    edited August 2019
    Houstan we still have a problem.
    Loading fine but when applying a pose in Carrara nothing happens with the clothing. Works fine in DAZ Studio.
    2528 x 1035 - 439K
    2431 x 1031 - 713K
    You converting to blended weight?
  • StezzaStezza Posts: 5,711
    can't get my G8Carrara man to load up .. throws morph loading errors.. so I loaded up G8CarraraGirl  and loaded the duds and shoes with no worries.. posed ok
    what I did do first though in DS was change the weight mapping of the items smiley
    now I gotta work out why the G8MCarrara won't load.. as I never use them I hadn't noticed before till now..
    does the DAZ studio man load?
    maybe your starter essentials borked
    edited August 2019
    Converting to blended weight and saving as a Support Asset worked, thanks for the tip !!!
    2269 x 1035 - 395K
    edited August 2019
    Thanks, Bunyip.  You have a very fitting character there for the outfit.  Great job!
    Here is a thumbnail of an image by MysticArtsDesigns.  Pretty cool.
    https://www.facebook.com/359446394900633/posts/450590009119604?s=100005480949655&sfns=mo
    edited August 2019
    Awesome render.
    I used some leather and metal shaders on my render
    1600 x 1200 - 3M
    luv his shoes heart
