Daz 4.11 stopped using GPU
I just finally updated Daz from 4.10 to 4.11. But since I updated, Iray is not rendering GPU anymore. I have a 1070 and a 660 Ti. I have all three (2 GPU and 1 CPU) selected in the device tab. But it's only running on CPU no GPU:
2019-08-17 00:26:53.431 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled2019-08-17 00:26:53.431 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Initializing local rendering.2019-08-17 00:26:53.432 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CPU: using 8 cores for rendering2019-08-17 00:26:53.433 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):2019-08-17 00:26:53.433 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : 	CPU2019-08-17 00:26:53.433 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...2019-08-17 00:26:53.433 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend progr: CPU: Processing scene...2019-08-17 00:26:54.058 Iray INFO - module:category(IRAY:RENDER):   1.3   IRAY   rend info : Importing lights for motion time 02019-08-17 00:26:54.059 Iray INFO - module:category(IRAY:RENDER):   1.3   IRAY   rend info : Initializing light hierarchy.2019-08-17 00:26:54.059 Iray INFO - module:category(IRAY:RENDER):   1.3   IRAY   rend info : Light hierarchy initialization took 0.00s2019-08-17 00:26:54.105 Iray VERBOSE - module:category(IRAY:RENDER):   1.3   IRAY   rend stat : Native CPU code generated in 0.0418s2019-08-17 00:26:54.170 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CPU: Scene processed in 0.737s2019-08-17 00:26:54.177 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CPU: Allocated 23.844 MiB for frame buffer2019-08-17 00:26:54.709 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : Allocating 1-layer frame buffer2019-08-17 00:26:54.777 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00001 iterations after 1.344s.
GPU-Z reports no additional memory usage.
I double checked that I have selected all devices before rendering. They are active in photoreal and interactive.
When I select one GPU only, it renders a black image.
What's going wrong here?
  • LeanaLeana Posts: 13,514
    Have you tried updating the drivers for your cards? 4.11 requires a fairly recent version of the driver.
  • I thought I have the latest, I will try that
  • Ok it seems I didn't have the latest installed. Works now, thanks
