What is this uniform depicted in this pose pack
daveso
https://www.daz3d.com/combat-specialist-poses-for-the-modern-warrior-pose-pack-2
I've searched but nothing I've found looks like that.
Post edited by Chohole on
I think it is one of the old V3 Uzilite outfits but I will search when I get home tonight. It is no longer available though....
It's a a kit-bash of several old outfits, mostly this https://www.daz3d.com/u-c-m-s-f-d , which is an add-on pack for https://www.daz3d.com/mos-invasion, and I think there's some old MIndvision stuff that isn't available anymore as well as some Uzilite.
awesome - THANKS ..now what are the odds of fitting that to G3 without too much agony. Bad the fact I can;t even remember what converter products I have...although I'm pretty sure I stayed away from old V/M 3 stuff.
There were some female equivalent Uzilite outfits which i bought in the day.... I think the male to female and m3 to G8F transformation makes it harder...
The helmet can just be parented, but as for the rest ot it.... the only direct clone converters from the V3 generation figures were to the original Genesis, so you'd have to do a double conversion to get to G3F, and a lot of generation 3 stuff tends to be real hit or miss and fall apart during conversions. Given that it's pretty obvious that the cross fit just from M3 to V3 wasn't very good to begin with, I wouldn't hold out much hope for getting a decent G3F transfer.. The V3 based MOS LIberator by Uzilite would probably transfer a lot better since it skips the gender conversion, and there were similar outfits made for V4 and M4 that would also probably convert better, like Uzilite's Complicated Eve.
V3 had Moon Over Saturn and MOS Liberator, and that was about as far as it went. She got Liquid Halo and Liquid Knight and add-ons for the more anime look.
M3 had MOS Invasion and the UCM-SFD add-on. There were a couple of texture sets to go with that from DzFire (still around) and 26FAHRENHEIT (no longer available). The Helmet and upper harness are from MOS Invasion. The texture used is Black OPs from UCM-SFD. The holsters are from Shadow Dancer. The boots, pants and top could be also, but they're pretty non-descript. (there is was a V3 version, now only for A3, and a V4 version, too).
The "Wear Them All - Autofit Clones Expansion for Genesis 3 Male(s) and Genesis 3 Female(s)" (that's a mouthful) added Millennium Generation 3 support to "Wear Them All - Autofitting Clones and Clothing Smoothers" for both Genesis 3 Male and Female. You could get the outfit up to G3M, then cross-fit to G3F.
Tried it, and some of the parts hanging off the vest get crushed (with Genesis and Genesis 3). They're attached as non-standard bones and are lost in translation, so maybe snip them off and add them back as props, but that's getting into a lot of work. Here's G3M with Shadow Dancer top, pants holsters and boots, and MOS Invasion vest and helmet, with the Black OPs texture from UCM-SFD, then Cross-Figure dialed in for G3F. There's even more distortion in the chest area (no surprise), so it would need some TLC to get it right.
I haven't looked but did Uzilite also sell some things through PoserPros... I will have to look through my runtime...
