A well a bird bird flew off with my complaint thread
1…1617192122…50
  • DanaTADanaTA Posts: 13,413
    Kyoto Kid said:
    ...but which path do I set it to?
    C:/Programme Files
    C:/Programme Files/Daz3D
    C:/Programme Files/Daz3D/DAZStudio4
    Are you using a UK version of Windows?
    Dana
    edited November 2013
    baffled by intersect, hd'scrch
    was hoping it cut a path through those in between edges to connect those 2 verts in a straight line.
    pick a plane?
    omg, potato/peas samosas soo spicy, hot hot,
    about time for an ice cream break. :)
    442 x 864 - 79K
    Post edited by Mistara on
  • kyoto kidkyoto kid Posts: 42,452
    DanaTA said:
    C:/Programme Files
    Dana
    ...heh, always spelled it that way. Most of my software that supports alternate dictionaries is set to UK English.
  • frank0314frank0314 Posts: 15,114
    DanaTA said:
    C:/Programme Files
    Dana
    That is a weird way to spell program
    Frank0314 said:
    DanaTA said:
    C:/Programme Files
    Dana
    Programme or Program
    Who invented the English language anyway. :coolsmile:
    Post edited by Chohole on
  • TJohnTJohn Posts: 11,448
    C:/Programme Files
    1. Did you install the previous version via the DIM? I did.
    2. If you look under Settings(the gear)/Applications in DIM, what do you see? See image below - this is what I see.
    3. Does your computer really use the British spelling for "program"? (not essential to answer :) )
    I can't guarantee results, but I can tell you that this worked for me. I have used the DIM to install 2 previous versions of 4.5+. In each instance the earlier version was replaced successfully and this time was no exception.
    562 x 529 - 41K
    chohole said:
    Frank0314 said:
    DanaTA said:
    C:/Programme Files
    Dana
    Some guys at Oxford...or maybe Webster...
    393 x 594 - 75K
    Kyoto Kid said:
    ...wouldn't that mess up the drive?
    I better try to get it off of the disc. The pudding is now dried on it which will make it a tad hard to remove. Any ideas of how to remove dried pudding from a disc. It is only on one size and that is the label but not on the read write area.
    "Chocolate pudding can be removed from a compact disc by one of the following methods:
    1. Hammer and chisel
    2. Belt sander" - The Bad Advice Handbook
    Sounds like it would be a funny read, that handbook. ;-)
    Dana
    tjohn said:
    C:/Programme Files
    ...yes it shows the same, but don't I have to specify the install path like I do with DS and Ps content or does it automatically know where to install the update (and dos it uninstall the previous version beforehnd)?
    Post edited by kyoto kid on
    woot Saturday night. wilder with hot cocoa and marshmallows.
    row row row your boat ... -is the song code for a sex thing?
    That sounds good
    Kyoto Kid said:
    tjohn said:
    C:/Programme Files
    Does your Settings/Installation pane in the DIM look like this? (The part about installing 64 bit and 32 bit programs)
    When the new version installed to my computer it removed the old version and installed the new one. I am going by the fact that there is only one version of DS on my computer.
    566 x 531 - 59K
    tjohn said:
    Kyoto Kid said:
    tjohn said:
    C:/Programme Files
    ...yes.
    There was someone on the update thread who mentioned that he ended up with two versions of 4.6 (both .1.17 and .1.33) in different locations in the same folder tree after installing which corrupted everything. That is why I held off installing until I could get this figured out.
    That sounds good
    The hot cocoa w/marshmallows or the "sex thing"? :)
  • starionwolfstarionwolf Posts: 3,670
    The content management system and smart content for Sutdio 4 did not work on my computer if I installed in another folder or hard drive.
    Post edited by starionwolf on
  • ps1borgps1borg Posts: 12,776
    Morning. Perfect sunny day, big blue sky and shirtsleeves warm so far :)
    Kyoto Kid said:
    ...yes.
    Right. I saw that too and it made me a bit uneasy as well, but there were reassurances from Admins and others so I took the risk.
    I don't know why things glitched for that one user, I haven't seen a post from someone else who had a problem yet.
    Yes, those appear to be "hard-wired" to only work with the C: drive.
    tjohn said:
    Kyoto Kid said:
    ...yes.
    ...I just didn't want to be the second one as I have no idea how to clean everything out, including the registry. :ohh:
    Kyoto Kid said:
    tjohn said:
    Kyoto Kid said:
    ...yes.
    wuh ohs - containment breach, we'll haz to jettison the cores capn
    That sounds good
    ... merrily, merrily ... , high on marshmallows :wow:
    ,18?
    i installed .17 just a few weeks ago.
    meh, fallback gallery form doesn't work in safari. upload button doesn't do anything.
    Test for HTML5 functionality here http://html5test.com/index.html
    chohole said:
    ,18?
    It needs an up to date Browser that can read HTML 5
    Safari does but functionality has changed the past couple of years....
    621 x 259 - 28K
    Kyoto Kid said:
    ps1borg said:
    Kyoto Kid said:
    ...found another cool looking Australian Sports car.
    Crikey, there were some neat designs from your neck of the woods.
    Love the Goggo carryalls as well. Way cuter than the VW microbus.
    Check out the Eureka sports volkswagon :lol:
    ...nice. Is that on the old air cooled chassis?
    I still have a huge soft spot for the older styles though.
    Getting on for fifty years old...
    I need to upgrade my copy of Opera.
    613 x 237 - 25K
    ps1borg said:
    ,18?
    oh dear.
    oh well, as far as i can tell, i have the latest safari for windows. it works for the important stuff, like the store. :)
    905 x 483 - 109K
    ps1borg said:
    ,18?
    oh dear.
    662 x 135 - 18K
    279 x 194 - 26K
    Dana
    1284 x 610 - 95K
    1284 x 610 - 95K
    Damn it! The first time I tried to post without any text...it said the message was empty, and it said no files were listed. So I attached the image again...and it came up twice. :-/
    Dana
