FWSA Jade HD for Teen Josie 7 for G8F?
argel1200
in The Commons
Anyone know how I can reach Fred Winkler or Sabby to see about comissioning a conversion?
Have you tried using this and this?
Yeah, but her eyes are really messed up after conversion. Large right eye socket and the left eye is vertical (taller than it is wide). I tried tweaking the tolerances to 0.045, 0.06, 0.09 then went crazy with 10 and -10 but always with nearly identical results. I'm guessing it's because she has HD morphs? That doesn't leave me a lot of options if I want to maintain character continuity across figure generations. I'm hoping it won't be as hard to covert her over with the source files (e.g. if Zbrush was used for the sculpt), though being based on Teen Josie 7 may complicate things. Anyway, if I don't ask, I'll never know if it's an option. She's my main character in a long run super hero role playing campaign and I have a lot of artwork based around her: [Edited for spelling]
https://www.deviantart.com/argel1200/art/Evelyn-Rose-as-Silver-Kite-Golden-Age-of-Comics-657054134
https://www.deviantart.com/argel1200/art/Evelyn-Rose-Silver-Kite-Collage-657054104
Just use X-Morph (Shape Splitter) or Morph Fixer to reset the eyes and ajust the position/size manually.
https://www.daz3d.com/shape-splitter
https://www.sharecg.com/v/88497/browse/10/Software-and-Tools/Eye-Jaw-Morph-Fixer-for-Face-Morphs
Thanks for the suggestions TigerAnna and Noah!! When I tracked the morphs down for Eye Jaw Morph Fixer for Face Morphs I noticed I had two conversion directories, so decided to just start clean witrh everything! I had Jade isntalled twice, via Connect/cloud and DIM, so I unisntalled both of those, deleted all the morphs created by Character Converter from Genesis 3 Female to Genesis 8 Female, then installed Jade via DIM, and Character Converter from Genesis 3 Female to Genesis 8 Female worked this time (tolerance set to 0.060).
