Is there a Thread/Area for Non Daz Iray renderings
Doc AcmeDoc Acme Posts: 1,153
Daz's assets are really top notch, and I know I'm not alone when I say I don't exactly see eye-to-eye with the DS interface, and that's not what this is about.  Everyone uses the tools they're comfortable with and there's never been one path to get to what that pesky minds-eye is seeing.  Ya know?
Only of recent have the stars, planets, and various hard & softwares aligned for me & agreed to play together nicely. For 3D work, I primarily use Lightwave as that's what my aging wetware has muscle memory for, & is much more friendly to ancient eyes.
The simple answer may be, just open a Gallery page.  And that may be it.
It's that I'm a bit gun-shy having gotten a posting deleted recently on one of Iray threads even though I very bluntly stated that it wasn't an Iray rendering & why.  Can't find any specific info that Galleries can ONLY be from Daz renders, hence the ask.
Bit a bit silly if it was, but ...
Anyway, here's what I'm talking about.
Mixture of Daz, Poser, & a few other assets in this case. Daz & Poser items exported via FBX from Daz & brought into Lightwave 2019. HDR lighting, surfaces to PBR, & UV's often restructured in various 3rd party tools. I've full FK control with the FBX hierarchy, but for the Andy character, I stripped that & re-rigged in a 3rd party Lightwave tool,(RHiggit 2), which gives me full IK control down to the fingers, which are set to FK.  Wonderful tool as you can mix FK/IK where desired.
TNX
  • Dim ReaperDim Reaper Posts: 687
    As far as I am aware, the galleries here are for any CG art you might make as long as it conforms to the TOS with regards to things like nudity etc.  Personally, I only post work here if it uses some Daz assets - so either uses some of their models or is rendered in Daz Studio.  Apart from that, I have posted images done in Vue (using some Daz assets), and heavily postworked images made from Daz Studio renders etc.
    I would imagine that your post was deleted from an iray thread because that thread would only be for iray renders.  You have a lot more freedom in your own gallery area of Daz3D.
  • Doc AcmeDoc Acme Posts: 1,153
    OK.  Good to know.
    Thanks.
  • LeanaLeana Posts: 13,391
    You can definitely post images not rendered with Iray or DS in the gallery. You could also create your own thread in the “Art Studio” section if you want to keep them in the forums.
  • TaozTaoz Posts: 10,320
    You could create your own thread for non-Iray renders.
  • BeeMKayBeeMKay Posts: 7,019
    You can also start your very own thread over in the Art section, and post there whatever pleases you as long a it's not against the TOS: https://www.daz3d.com/forums/categories/art-studio
