looking for an opera cape/cloak
gabu
a full length cloak that hangs from the shoulders and can wrap around to the front and be fastened
for genesis preferably
unfortunately the genesis hooded cloak doesn't seem to wrap around to the front, it only falls from the shoulders to the rear, unless I haven't found the right movement morphs
thanks for any help
Did you try Wilmap's cloak on ShareCG?
thanks for the pointer
but I went over the sharecg and looked at wilmap's gallery and there doesn't appear to be any cloaks in it
can you give me the sharecg url
thanks
Only things I have on Share are the following, but I don't think they are quite what you are looking for.
http://www.sharecg.com/v/68958/view/21/DAZ-Studio/Genesis-Hooded-Gown
http://www.sharecg.com/v/69764/view/21/DAZ-Studio/Genesis-Victorian-Sleeveless-Cape
that looks like just what I want/need
all I can do is to encourage you to keep at it and hope it will appear in the store before too long
all I can do is to encourage you to keep at it and hope it will appear in the store before too longI hope so too, but right now I'm at an impasse because I don't know how to make JCMs, FBMs textures from scratch (only modifying existing textures). For the lining and trim, I'm using the free World of Satin shader resource pack from ShareCG, but for the outer surfaces, all I have is a Velvet shader which is not a resource pack, so I can't use that in the final product. It needs an actual wool texture made with bump maps. What I really need is an existing PA to collaborate with to finish it. I've gotten it as far as I can on my own.
Well, I do hope that you can bring it to fruition before too long.
From my point of view what textures it comes equipped with 'out of the box' is not so much of importance. I would still be interested in it even if it was untextured. I have got quite a selection of cloth shaders to play with. For me the main thing would be that it has a lot of surfaces defined so I can easily apply the shaders. As well as lots of movement morphs of course.
From my point of view what textures it comes equipped with 'out of the box' is not so much of importance. I would still be interested in it even if it was untextured. I have got quite a selection of cloth shaders to play with. For me the main thing would be that it has a lot of surfaces defined so I can easily apply the shaders. As well as lots of movement morphs of course.It doesn't use morphs for movement. It uses bones, and lots of them. As I said, it has 45 bones for movement and posing. It also has five material zones, the outer shell, the inner lining, the capelet outer shell, and capelet inner lining, and the trim. The capelet has its own material zones so it can be turned on and off separately.
