Is there "Ultra High Resolution" for HD models?
Hello!
For some models, I see the "HD" attribute on the DAZ store, for example here: https://www.daz3d.com/michael-8-hd-add-on
How is this realized in DAZ? Is there a Resolution Level "Ultra High Resolution" in the Parameters slot?
Or are the details in the normal map?
Thank you for the info!
HD morphs work on the "virtual" vertyices created by sub-division (as does displacement in Iray). The number of levels used is decided by the morph creator - usually 3 or 4 (64 or 256 times as dense as the base)
