Loose Pigtails G3F Help
Hello all.
I seem to have an issue with the Loose Pigtails for Genesis 3 Female. The hair appears normally within the Scene, but it shows up as just a colored "blob" of sorts on the figure when rendered. I tried playing around with things such as diffuse color, specular overlay, cutout color, etc, but still get the same result each time. Photos below.
Used this hair on a G3F (left) and G2F (right)
  • MelanieLMelanieL Posts: 7,872
    Is that an Iray render or 3Delight? That hair has Iray surface settings only, so won't look right in 3Delight.
    Don't have it but product page says it comes with IRay mats only. Do you render in IRay?
  • jhand002jhand002 Posts: 12
    It was a 3Delight render. I missed the part about it being Iray only. Thanks again.
    You can certainly convert it to 3DL if you need to, either manually (start by locating and loading the cut out opacity maps into the opacity channel) or by using one of the converter scripts.
