Some assets needed to load this file are missing but none are listed.
I created a bunch a custom morphs and saved some of them as support assets. After changing and removing some of them, I get the following message whenever I open a scene with that character, "Some assets needed to load the file were missing. The content may not work as expected." The problem is that it does not specify what components are missing so I have no way to know what to fix. How can I fix this or dig deeper to see what is actually missing? I've seen this screen in the past and was able to fix it because it listed the missing morphs, but I'm not sure how to proceed when there's no info.
I ended up checking the log file and saw that it was referencing the previous location for the scene file for some reason, so I added a copy of the scene file to location and that appears to have fixed it.
I have discovered the issue. I had to go into Hair>Face and there was an icon labeled "Beard apply". Apparently, I had to do that first, then could select the colors
Thank you for your replies!
