Error 404(15)
lorddayradon
Post edited by lorddayradon on
lorddayradon
Ease in - ease out is the default interpolation type in DS. If you own the keymate and/or graphmate plugins you can change the interpoation to constant or linear. You also have the option to tweak the spline curve and see in the graph exactly what is happening, using for example bias, tension to shape the curve. So I suggest, if you don't own the plugins and want to animate in DS, get them! Or atleast check for free scripts by mcasual in the freebie thread! And a tip, make sure on frame 0 you have set keyframes for every bone and every translation and rotation before starting to add keyframes. Easiest way is go to frame 0, select your character in the scene tab and expand all, select them, go to the timeline and click on the + button.
Sorry forgot those plugs are now included in the new DS build;)
They have their own panes, yes, but with the latest DS build I understand they are sort of integrated with the timeline. Here's a recent thread you might want to check out: https://www.daz3d.com/forums/discussion/341016/who-wants-better-animation-tools-in-daz-studio/p1
Graphmate is good for selecting one or more parameters (like hip z-rotation) and see a graphical representation of the splinecurve. You can then edit it using a number of tools, or move/copy-paste or delete keyframes. Keymate don't show the graph but a timeline with the keyframes for every visible object/figure in the scene. It's great for moving or copying etc many keyframes at once, and for setting the interpolation type for a bunch of keys. Long story short, you need both:)
Those pluggins just edit what's in your scene. So once you have saved the scene like you normally would, you're safe:) Or if you'd rather save as an animatable pose preset, sure, whatever suits your needs.
You would need the 4.12 beta build for the intergrated timeline ; or the separate graphmate/keymate plugins - they need to be registered
Or, if you don't have the plugins, set the interpolation to linear with mcasuals script
https://sites.google.com/site/mcasualsdazscripts/setinterpolation-for-ds2-3
I'm sorry, did a search and they seem to have been pulled from the store:( They now seem to be integrated with the new DS Public Beta build, which you need to "purchase" for free. https://www.daz3d.com/daz-studio-beta
You can run it alongside your current build. For more info (or questions) check the official beta thread here: https://www.daz3d.com/forums/discussion/341006/daz-studio-pro-beta-version-4-12-0-42-updated/p1
Great:)
