Dakotaraptor colors
Dear,
I just purchased the Dakotaraptor model.
I read the capability of "... different feather displays, and different skin colors".
I can only see one grey tone color in materials that could be changde from light or dark.
How can I change the skin color as I see in the attached image ?
Thanks a lot, Xavi
  • FSMCDesignsFSMCDesigns Posts: 12,855
    That image doesn't look like an additional texture, it looks like material zones. go into the surfaces tab and see if you can select those areas. If so, then add a color to the diffuse section to make the feathers different colors.
  • xavieratorxavierator Posts: 161
    Thanks for your answer, I wil ltry it
    Xavi
    Dear,
    I'm making tests, see the first attached image to see a names scheme.
    I'm trying to create a dakotaraptor like second attached image.
    With dark or medium colors it works fine, but with light colors it doesn't work, for light color I use the third attached image reference (RBG 255, 245, 220).
    It seems right in the Aux ViewPort, see the fourth attached image.
    But not in ViewPort, see the fifth attached image.
    And of course not in final render, all results are darkness, see the sixth attached image.
    Is it possible to create a white/brown dakotaraptor changing the base colors in surface tab ?
    Thanks, Xavi
    1300 x 1000 - 439K
    804 x 430 - 63K
    496 x 52 - 12K
    121 x 228 - 12K
    354 x 699 - 54K
    429 x 599 - 91K
  • felisfelis Posts: 6,343
    I don't have that product.
    But you shall be aware of that all the settings in the surface tab, will influence how it is rendered. The viewport is a simplified version of the expected result.
    My advice is to go through the surface tab and look at the other inputs like translucency colour if there is such.
    Other colors are:
         Glossy Color
         Emision Color
         Line Preview Color
    Thanks, Xavi
  • chris-2599934chris-2599934 Posts: 1,956
    The base color channel that you showed us...
    ...contains two components. The square box under where it says "Base" shows the image that's being used in this channel, the rectangular area to the right of it shows the creamy colour you've chosen to overlay that image with. The end result is a combination of the two - the brown image modified slightly by the creamy overlay. That's still going to end up quite brown.
    If you click the image box, it'll give you the chance to browse for a better image (if there's a greyscale bump map image for that surface, that might work) or choose to have no image at all. Experiment and see what you can come up with.
    Nearly perfect Chris, new attached image
    I will continue in this line
    Thanks, Xavi
    1415 x 2004 - 1M
