Concert Stadium
I've been looking for a big stadium for a concert scene. But I can not seem to find one. Daz 3d has a metro music hall and other items, but I would like a huge concert stadium. Inside it could have a ticket booth,concession area,relaxing area, and the main concert room. Thank you
    I'll stick to smaller venues for my concert scenes=)) Without using billboards a stadium with maybe 20-30 genesis characters would look...well you get the picture:D
    This guy is making a circus...incredible work indeed...and he's not using billboards, don't know how that's even possiblesmiley.
    Link to his art thread https://www.daz3d.com/forums/discussion/193331/the-most-detailed-circus-model/p1
    Oh, he mentioned he's using 24 characters and instances;)
  • FSMCDesignsFSMCDesigns Posts: 12,851
    Quite a few stadiums here. Find one that is in .OBJ format and import it into DS.
    https://www.turbosquid.com/3d-model/stadium
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,661
    In one go it would be difficult but composition is doable
    transmapped planes for figures instanced and backgrounds rendered first even a 360 panorama
    maybe the stadium then build up rows of people with more layered in front and then the front barrier fence each as a 360 with bigger more detailed renders each layer, you then have the environment dome to rotate for your foreground.
    This is even doable animated using Hitfilm express as it can do 360 images in layers.
  • vwranglervwrangler Posts: 5,000
    edited July 2019
    What do you need the stadium to do, exactly? I mean, yes, be a stadium, but do you need it to be populated? Do you want to do still images of people performing along with an audience? If so, you're going to need billboard people (Now-Crowd or some such) as well as your main characters, to keep your system from falling over dead, unless it's immensely powerful. Also, I don't think you're going to find everything you want in one product.
    Regardless, the only solid very large outdoor stadium product I know about -- assuming you're talking about an outdoor venue and not something like Madison Square Garden -- would be the Truform Stadium at Renderosity: https://www.renderosity.com/mod/bcs/truforms-stadium/116621/
    Technically, it's in Poser format, but it's easy enough to use in Studio. (Also, Camera depth-of-field will be your friend there, to blur the seating.) It doesn't have all the things you want, but you should be able to repurpose existing rooms for those.
    If you're talking about an indoor concert hall ... well, there's Event Complex (https://www.daz3d.com/event-complex), which has a lot of what you want, but isn't the easiest to use. Also, it's both bigger and smaller than you want, I think -- it doesn't actually have a huge number of seats, necessarily, but the structure is big enough that a computer can struggle with it. Apart from that, the recital hall, Metro Music Hall and Lotus Flower Auditorium (https://www.daz3d.com/lotus-flower-auditorium), and Auditorium with Props (https://www.daz3d.com/auditorium-with-props) I'm not sure that anything necessarily exists for what you need. (And I can tell you from experience, Lotus Flower needs a bit of tinkering to make a suitable concert hall. It's not quite designed for that.) And, again, you'll need to use items from other than those products to get the rest of what you need.
    The relaxation room can be any room, really. Something with a bunch of couches and the like, I guess.
    The concession area, you'd need to get from something like the i13 Theater (https://www.daz3d.com/i13-theatre-with-poses) or i13 Bowling Alley (https://www.daz3d.com/i13-bowling-alley-environment-with-poses) -- those will both certainly be on a deep sale again in the relatively near future. The Theater has a ticket booth, but since it's connected to the theater front, that might not be suitable. For that, you could use the ticket booth from Moonshine's Drive In (https://www.daz3d.com/moonshine-s-drive-in-movie-theatre). And so on. Look for the individual things you need, rather than trying to find them all in one, because that doesn't seem to exist at the moment.
    Post edited by vwrangler on
