My Projects in 3D Digital Rendering
1…1415171920…25
  • RakudaRakuda Posts: 938
    edited July 2019
    Back to the Frozen Custard/Icecream Stand:
    Here are the latest progress shots of the low-poly environment.
    When the "billboard" trees are dropped in and they are oriented to the camera, the scene is going to really
    start to come together.
    Does it remind you of a monopoly board, or maybe Mr Rogers Neighborhood with the low-poly houses?
    Would be kind of fun to play with the DOF and get that tilt-shift effect going on.
    1765 x 874 - 1M
    1823 x 867 - 2M
    1782 x 812 - 2M
    640 x 472 - 537K
    Post edited by Rakuda on
    edited July 2019
    1200 x 675 - 764K
    1200 x 675 - 813K
    927 x 1200 - 877K
    edited July 2019
    Status Updates: getting really close
    1605 x 830 - 110K
    413 x 802 - 15K
    1531 x 619 - 213K
    1561 x 832 - 251K
    1503 x 859 - 261K
    1446 x 698 - 388K
    1081 x 862 - 1M
    edited July 2019
    Side render: The Wisdom of Age
    "One does not live on bread alone"
    Used: Etta HD for Edie 8
    Just an idea that I was playing with regarding aged hands and old books
    837 x 855 - 234K
    edited July 2019
    Here are some late stage low resolution renders. I am getting ready to do some final texture adjustments and add the vegetation now that the modeling is complete.
    1842 x 835 - 3M
    1845 x 912 - 3M
    1851 x 808 - 3M
    1834 x 872 - 2M
    1831 x 738 - 2M
    edited August 2019
    Here are some close up detail shots of the Ted Drewes Signage and a trash bin.
    Getting very much closer to a finish.
    1274 x 625 - 384K
    1266 x 625 - 433K
    1229 x 625 - 412K
    edited August 2019
    Side-Render Project
    Here is a little side project for a weekly contest. This is the first rough-draft. Need to pull the
    concept together by the 6th of August.
    In the first round of critiques I would  say that I need to do something with the suit the old guy is wearing.
    It needs to fall dynamically to look right. Also, I have to play with Angles and poses.
    Gotta use one of the poses from this Off Road Adventures Poses set. The leaning pose against
    the truck-bed might be good.
    ^__^
    1200 x 675 - 413K
    edited August 2019
    As the  Frozen Custard Stand is progressing and coming to resolution, Another project being worked
    on in the background is a scene with the Skidmore Fountain in Portland, Oregon. This is  being scuplted
    in ZBrush. Here is Phase 1 of that project.
    I sort of wanted to see the robe and hairdo made in a way that could be applied to a Genesis2 or Genesis3
    figure. That would be interesting. I didn't get any takers who could create the hair, although there is a similar
    classic style robe in the store.
    1067 x 1600 - 345K
    1120 x 823 - 199K
    edited August 2019
    Bits and pieces coming together!
    Now, more time needs to be spent again developing some poses. This time I need a few poses for female figures for the context.
    833 x 554 - 236K
    323 x 956 - 170K
    488 x 961 - 218K
    1681 x 785 - 858K
    1553 x 755 - 2M
    edited August 2019
    the dish is evolving as s the proportions of the Sculpture of the Skdmore Fountain. I think the detail on the bowl can be handled with a normal map. That will keep the geometry simple.
    1147 x 947 - 200K
    edited August 2019
    Icecream Stand Updates
    500 x 371 - 159K
    1784 x 855 - 2M
    500 x 371 - 175K
    edited August 2019
    Here is a test render
    I have to put some texture on the buildings and simulate some architecture in the far distance as well as coloring up the signage. Nevertheless,  it is getting excitingly close to completion.
    This project has gone on for a little while and quite a but of effort has went into it.
    Coming up soon will be the peopling of the scene. This will include figures inside and outside the restaurant. Inside I will turn the lights on  and have the workers working, This stage is quite exciting as it seems  things are coming together really well.
    Update:
    I saw a new product Orestes Iray HDRI Skydomes - Vanilla Evening by Orestes come out and I had to snap it up because it would enhance this project so perfectly!
    Also notable, I used Forests Trees and Grass World Building Set, but not right our of the box. I had to go into Hexagon to isolate individual trees. It would be super if the package allowed you to just load one tree at a time.
    1236 x 1236 - 882K
    900 x 900 - 542K
    edited August 2019
    Test Render of Gabriela 8
    900 x 1165 - 577K
    900 x 1165 - 599K
    edited August 2019
    The Magician
    Made an attempt to put stripes on the X-Fashion After Hours Suit for Genesis 8 Female(s)
    900 x 1165 - 741K
    900 x 720 - 353K
    900 x 900 - 669K
    edited August 2019
    Update on Skidmore Fountain
    Here is a progress shot from the fountain project. It is nearly done with modeling.
    1200 x 829 - 71K
    edited August 2019
    An array of Athletic Poses that I set up
    1800 x 2321 - 480K
    edited August 2019
    Revisiting a render from the past
    In the past I rendered this image but only with Scene Only mode. This time, I loaded up an environment HDRi and tried to get a cleaner lignting. The shadows are softer but the overall light is better. To get sharper cast shadows it might require upping the scene lights a degree... if I want to do that. Part of what is compelling about the image is the powerful shadow which represents pent-up internal energy, so I think I might want to.
    This was only rendered for around an hour. In order to go full-render it will need to render overnight.
    Previously:
    It is interesting to compare the histograms of the two images:
    Here  is after taking the new image into Photoshop and doing a Image > Adjust > Match Color with the old image as the source. Kind of intense, but it laks a feeling of subsurface.
    1200 x 1553 - 1M
    1229 x 527 - 192K
    1200 x 1553 - 431K
    edited August 2019
    Just messing around
    1800 x 1440 - 1M
    1800 x 1012 - 990K
    1800 x 1800 - 1M
  • HylasHylas Posts: 5,345
    Love your lighthouse and magician!
    Although the latter bears an unfortunate resemblance to Michael Jackson... indecision The Tim Burton vibe is great, though!
    @Hylas the MJ thing hadn't occurred to me. But I can see what you are saying.  The lighthouse reminds me of places I have been in Oregon.
    ^__^
  • algovincianalgovincian Posts: 2,703
    That HDRI adds a perfect diffuse light to compliment the flourescents in your Drewes scene. Reminds me of a local place down here by the lake where the lights are that same yellow. I can just imagine the crowded scene on a summer night - looking forward to seeing it all populated! I'm curious whether you plan to render with DOF? Also, your poses look spot on. Great work in this thread.
    - Greg
    Totally agree about the MJ resemblance. Is that a D.Master character?
    - Greg
    edited September 2019
    A bit of play with a Dojo setting (Dashi Hari) Foot Sweep.
    1800 x 1440 - 1M
    edited October 2019
    Working on a dress for another proj. This is to fit a Genesis 2 figure.
    1920 x 1080 - 3M
    edited October 2019
    Finished Dress
    1200 x 1553 - 2M
    edited October 2019
    .A variation on the 1800's Dress
    1200 x 1553 - 2M
    edited January 2020
    Empty Spaces
    1145 x 1483 - 2M
    1145 x 1483 - 650K
    edited October 2019
    Anticipation
    Need to find a good dforce skirt for this pose to get more natural effect.
    1200 x 1553 - 469K
    edited January 2020
    Playing around with a pool setting and Ron's Underwater Air. Need to study the air bubbles a bit more to make it a litle more realistic as far as placement.
    3200 x 1800 - 3M
    3200 x 1800 - 7M
    edited January 2020
    A walk by the waterfront
    Doing a drawing based on the setup
    1600 x 2071 - 2M
    1600 x 2071 - 1M
