Genesis to G2F Texture Conversion
LucynskyLucynsky Posts: 64
Not happening.
I pick all of the surfaces, and switch the UV map from "Basic Girl" to "Victoria 5." The face looks all right, but the rest of the seams don't line up.
I tried it with several textures, but some were better at hiding the seams than others.
Am I missing a product?
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Are you sure the right, V4 UV-using, maps are applied?
  • LucynskyLucynsky Posts: 64
    Do I need those with a genesis texture? If so, then no, I don't have the V4 to G2F thing.
  • JaderailJaderail Posts: 0
    edited November 2013
    The only textures the G2F can use right out of the box are G2F texture (Basic Female) and V5 textures. The texture you apply must be a Native V5 UV texture from a V5 Character set. It does not mean you can use a V4 texture on G2F as you can on V5. You can get the V4 clone for G2F and then you can load all female textures Genesis uses with some conversions needed for some.
    Post edited by Jaderail on
    Sorry, I misread - I thought you were using the Victoria 4 fro Genesis 2 Female set. Your materials presets do need to be in .duf format, as far as I know - and you need to be sure that the maps are fro the V5 UVs, a lot of "so-and-so for V5" characters use the V5 morphs but the V4 uvs.
    Oh, they must one of those. Ok, makes sense. :)
