[Solved] Iray Canvases: Emissive surfaces not contributing as much to litghting as I expect
Joe827Joe827 Posts: 242
I am trying to render a specific object frrom a scene as it's own layer for postwork.  This object has some emissive surfaces on it.  Full scene looks great.  However, when I render just the specific object using canvasses and the "beauty setting", the emissive surfaces have a much less intense glow (maybe 25%).  If example images are needed, I can provide.
I am still learning canvases and I'd really like to be able to render specific objects within a scene without any impact to the lighting of the scene.  Does anyone know how to do this when emissive objects are involved?  Thank you for your time.
Post edited by Joe827 on
  • nonesuch00nonesuch00 Posts: 18,856
    I usually change the  unit of measure from cd/m2 to kcd/m2 for a 1000-fold increase. That is often too bright  then and so decrease the default number from 1500.
    Also as your render progresses and more details of light & shadow are added the rendered scene can sometimes be more what you expected.
  • Joe827Joe827 Posts: 242
    edited July 2019
    I don't think we're talking about the same thing here.  In the full scene render, the emissive surface intensity is exactly what I want.  But when doing a canvas render of a single object, the emissive lighting fades (or is being ignored in some way?).  I will post a side by side comparision to help illustrate what I mean.
  • barbultbarbult Posts: 26,863
    This video might be helpful. Be sure to watch part 2 also.
    Thank you.  I will give it a try.
    Thank you barbult.  I believe that got me over the hump.
