Wacky Modelling ~ In Carrara ~
12627293132100
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,281
    I wahn it I wahn it.... YOU CANT HAVE IT!
    now I have my magic bus too much magic bus yes
  • Bunyip02Bunyip02 Posts: 9,275
    some wipers added and more texturing .... I'm not going to attempt the interior...!
    it's got morphing opening doors though wink
    that might be it for now... do you think it's passable?  ... I may bag it up and post it later after a few render tests yes
    Excellent !!!
  • StezzaStezza Posts: 8,816
    edited July 2019
    ok.. the wacky bus is in the terminus.. buy your tickets and climb aboard
    you will need to adjust some shaders probably, I'll attach the template and body textures in a zip file for you to play around with.. hope you can do something with the interior.. share if you do wink
    the doors have a morph to open and close.
    have fun yes  smiley
    zip
    zip
    Bus by DaveT.zip
    2M
    zip
    zip
    Bus_Textures.zip
    1M
    Post edited by Stezza on
    you will need to adjust some shaders probably, I'll attach the template and body textures for you to play around with.. hope you can do something with the interior.. share if you do wink
    have fun yes  smiley
    Many Thanks !!!
  • DesertDudeDesertDude Posts: 1,239
    I'm woefully behind in this thread...great work everyone, thanks for sharing and inspiring and workflows!
    edited July 2019
    prob better to chuck the images into a zip as otherwise thanks to DAZ have to be converted from that webp format
    iClone version,
    still trying to populate Carrara bus
    keeps going frozen and bugging out trying to use Genesis 3 FBX from iClone,
    from DS with 3DU toons on Misty's presets will be harder but I may have to
    yes  smiley ... yep updated them to zip...
    edited July 2019
    This bus should get plenty of mileage !!!
    Have included Stezza's bus with my reskinned colour scheme for those that might be interested
    2400 x 1361 - 5M
    7z
    7z
    Bus by DaveT-Central Plaza.7z
    6M
    1654 x 782 - 1M
    Post edited by Bunyip02 on
    edited July 2019
    Another reskin - Metro Bus
    1588 x 775 - 602K
    7z
    7z
    Bus by DaveT-Metro.7z
    7M
    edited July 2019
    that would be a fun thread to start.... bus adverts lol
    converting the wacky bus to LH drive ( those funny countries that do it ) is a pretty simple process... just select the few parts that need to be reversed and in the modeling room duplicate with symmetery without welding and move into place and delete the bit you copied.
    not many parts need doing... the bus shell, floor, doors, dash, seats and swap the windows over... move the steering that's about it... I think.. surprise
    if you want to animate the wheels to go round and round you may have to delete the ones on the LH side as you look from the front then duplicate the other two and move and rotate into position.. I used duplicate with symmetary on them and Wendy had some wacky results.. which is cool.. it is a wacky bus.. yes  laugh
    Have fun experimenting
    800 x 600 - 268K
    Maybe Misty could have a bus decoration challenge ?!!
    WitchHouse in TwinMotion
    sadly I am having constant BlackScreens of Death so how much rendering I can do is questionable
    my PC works and this video proves my 980ti does as it rendered it!!!
    but my monitors stop getting a signal and I cannot use my PC and have to shut it down
    What windows version?   A couple of us suffered with a similar sounding problem after running one of the windows 7 updates,  which was then cured with yet another windows update a bit later.
    edited July 2019
    I uninstalled that optional July18 update too but still happens
    was up to date
    Win7 Micro$oft prob sabotaged it
    now downloading 430.86 driver
    Stezza your model one of the few things I can fit easily in both Twinmotion and Flowscape
    I have tried DAZ figures but they struggle
  • DiomedeDiomede Posts: 15,398
    So much good stuff going on here.  Just dropping in to say that I just took that bus across Iowa.  If you said, "where?" then you understand.
    Seriously, great bus model.
    I like what you did Wendy ... awesome ... yes
    thanks Ted... doing a bit more on the bus model today cool
  • UnifiedBrainUnifiedBrain Posts: 3,588
    edited July 2019
    This is amazing!  Is it Twinmotion, or is it Flowscape?  Are the people and their animated motion native to the program?
    Stezza's house model looks terrific with those various shader modifications.
    Post edited by UnifiedBrain on
    Both,
    the shots in Twinmotion have the seas, huge terrains and speedtrees animated 3D people and various animals that walk traceable paths, lots of modern people holding phones with looping idles, it’s an ArchVis program primarily, has cars that follow paths, ships, planes, busses, animated bike riders, furniture,
    you need an Epic Games Launcher
    Twinmotion is also free
    Flowscape is pretty cool too but more limited import, very cheap, it still has pretty awesome plant painting and animated animals, fantasy figures
    edited July 2019
    Luthbel MICK bedroom in Twinmotion with lots of the 3D animated people
    It handles much bigger imports
    both only static objects
    Both,
    Thanks for the answers.  Not everything is clear, but that is OK as I don't really have the time to investigate it more fully at the moment.  I'm glad that you do!
    Gotta admit, the quality of the video startled me a bit.  Given the obvious constraints, the results you can achieve are getting closer to Pixar.  The effect of wind, for example, seemed very lifelike.
    Just search Twinmotion on YouTube, there is a huge amount of stuff
    edited July 2019
    did some more wacky bus stuff
    redid the body, added some interior with an interior lining, changed the wheels to see if fixes the wacky twirling in animation... mmm... probably did other things that I can't remember.
    Going out to lunch today so won't get it posted till much later.. but here's a wacky wip pik
    800 x 293 - 168K
    edited July 2019
    the bus took a short detour ... will be back soon...
    in the meantime I modeled this wacky character as an authentic replacement for any TRexes you can't get into Carrara..  devil
    experiment time on the old fossil in the zip file
    640 x 480 - 205K
    zip
    zip
    Rex Dino.zip
    138K
    Cute, might need to do a battle between him and Vyusur’s Dino heart
    rock em sock em dinos smiley
    Awesome !!!
    edited August 2019
    a wacky Reliant 3 wheeled car ....  seen a post on it the other day on another forum .. thought why not... Mr Bean picks on this car all the time!
    800 x 600 - 208K
    Very nice - needs a Scammell Scarab to go with it !!!
    edited August 2019
    since my Graphics card keeps crashing and not recovering using Octane, iray, Twinmotion, Flowscape etc
    I decided to do some modelling
    and revisited the rollercoaster but UV mapping the bugger impossible
    put what I have in a zip
    https://www.daz3d.com/forums/uploads/FileUpload/99/2c3cb47326b2e557eb5fdd1174e88c.zip
    1920 x 1080 - 124K
    zip
    zip
    rollercoaster2.zip
    619K
