Black areas on Hairline when rendering in Luxus
Note this only happens with 1-2 hairs that I have, all other hairs render fine with Luxus
The hair is Smay's Stalker Girl hair. I dont know why it does this, I have loaded a entirely different hair shader using Right-CLick+Ctrl
but the problem still persist
Without a screenshot it's hard to say anything.
Well anything but: loading a different hair shader should make no difference if you're rendering via Luxus.
Are you sure it's not just the mesh of the figure poking through the mesh of the hair?
I would guess transmap issue easily fixed with render settings:
-> http://www.daz3d.com/forums/discussion/18543/P960/#286366
Or could be shadowed facets.
-> http://www.daz3d.com/forums/discussion/21492/P345/#426289
Hey it was definitely a transmap issue and was solved by setting Eye Depth to 16
So glad I can now use this hair in Luxus
w00t!!!
Thank you for the help and czexana for the render settings
