Adding to Cart…
Thanks. If Daz can figure out something, it will allow me more time for creating things and less time in the support threads.
Hi RiverSoftArt!
I've sent that help ticket, and they have fixed the issue: now I've installed both products with Daz Connect and they work!
I hope this has fixed the issue in general, so that everyone will be able to use them this way! :D
Oh that is fantastic to hear! I hope it does fix others' issues. Thank you for following up with this!
You're welcome, have a nice day! :D
So, I am suddenly having trouble with virtually everything this converts. And the only fixer morphs are Expand all. I know I had an issue earlier with a connect update, but I uninstalled the DIM version today and installed Connect from scratch. Shoes, full body and torso items are NOT fitting properly at all.. they are all shifted down.
There hasn't been an update with this product since January. What has changed on your system recently?
Nothing. As stated, I removed the DIM version, reinstalled from Connect. Same results.
I'll post some pictures shortly.
These are largely all new G8 male items by ihkang, or H&C.
Here is the Expansive APE suit, just to show its not only the ihkang products
ihkang Bomber Jacket set
Did your base character model get accidently modified with a changed scale factor or some morph always dialed in? Some products are being sold lately with morphs that apply to everything, not just the character the morph is supposed to affect.
You could try to use the "old" conversion algorithm. You can force the script to use it by:
https://www.daz3d.com/forums/discussion/comment/4090206/#Comment_4090206
By doing that, it should raise the shoulders slightly.
Not that I can tell. I have loaded the model various ways. But I will double check
I'll try this, but... what about the shoes?
No morphs no scaling, stock Genesis 3 Male
Hopefully you meant Genesis 8 male not Genesis 3. If I remember the instructions correctly, you should have a G8M in the default pose, not G3M.
The shoes you would convert normally. I am just trying to get the other code path to run for the shirt/jacket.
No, I meant Genesis 3 Male, because I am going from 8 to 3. But it would seem I posted this in the wrong thread.
Ah, ok, no problem. The G8M->G3M was updated at the same time (January). So, one thought, do you have multiple converters installed? Perhaps uninstalling all of the others and making sure there are no wayward files anywhere might help.
