Graininess Around Sunglasses
Hi,
I rendered this in iray and am wondering if anyone has any suggestions for how to eliminate the graininess around the sunglasses.  Is there an iray tutorial anywhere?  Thank you.
RiverMissy
  • HylasHylas Posts: 5,284
    Let it render longer.
    If this is the result of rendering to completion (100%), then increase Rendering Quality, which can be found under Render Settings -> Progressive Render Settings
    If this isn't the result of rendering to completion (100%), increase max time, which also can be found under Render Settings -> Progressive Render Settings
    You don't have to render the entire thing again, you can just render that one spot and merge the result afterwards in a graphics editor (such as Photoshop or GIMP). Go to Window -> Panes (Tabs) -> Tool Settings. Select the Spot Render Tool and select New Window. Now use the mouse to select only the problematic area. DAZ will now render only that one spot.
  • RiverMissyRiverMissy Posts: 320
    Thank you I will give this a try.
  • markusmaternmarkusmatern Posts: 611
    You could also denoise the render afterwards, which is usually very fast!
    The attached image is postprocessed using the Intel Denoiser described in this thread:
    https://www.daz3d.com/forums/discussion/334881/use-this-a-i-based-open-source-de-noiser-from-the-comfort-of-daz-studio
    or in this one:
    https://www.daz3d.com/forums/discussion/316206/denoise-renders-and-save-a-lot-of-time-nvidia-not-reqd
    600 x 600 - 499K
    Hi. That is a very interesting looking script you have put together.  I will look into trying it another day when I have more time.  Thank you.
