Adding to Cart…
You didn't mention which basecharacter this is for, or if you still render i 3DL. I'd start by going through all the demonic stuff in the store to find a suitable skin, something that could easily be modified.
Just checked RawArt's products, found a couple of skins I could use myself:)
https://www.daz3d.com/handsome-harvey-mutant-for-genesis-3-male
https://www.daz3d.com/krampus-demon-for-genesis-3-male
https://www.daz3d.com/dead-fred-for-genesis-3-male
These could be made highly glossy/reflective. Diffusecolor /SSS color could be tinted/overdone=) Additionally a geoshell could be used to add a matte layer if needed. I'm sure there are a lot more products you could use:)
I obviously switched to Iray since now I own the GTX1080ti card :) Dead fred actually looks good as a base, I would have to try it on Gen8 Female body though. I'm using different actors, but Vicky 8 primarily.
Quite interesting, I found an amazing texture on pbrtexture.com [ link ]
It comes with several maps:
Diffuse 4096x4096
Metalness 4096x4096
Roughness 4096x4096
AO 4096x4096
Normal 4096x4096
Displacement 4096x4096
I'm going to experiment with it, but i still need to find a way to seamlessly blend, for example Victoria's diffuse map with this texture, so her body details on the texture (like shading under the breast etc) is not lost...
