Can't save poser companion files.
Alric
Ok, first off I had no problem converting these files on my home computer but when I tried it at work it fails.
I'm trying to create poser companion files for a number of clothing items.
The items are already in .DUF format (they are age of warriors: Celts 1 and 2).
All my poser and DAZ libraries are set up.
When I select an item and the select "Create Poser Companion Files" the I select the proper directories and get an error message that says:
"The following list of files couldn't be converted because they are of an unsupported content type and/or extension:
006 - Amor.duf"
The extension is .DUF so that is correct, and the content type is supported because I was able to convert it last night.
I checked and all my software looks to be up to date.
After more testing I think I have identified the problem.It looks like the Metadata for the files is bad.
If I choose "let metadata decide the file type" when saving the companion file it fails. If I select the file type then it works.
