How can we change thumbnails ?
JamyJamy Posts: 192
Hi everybody,
After long search on the forum, I can't find the good way to change Thumbnails in my personnel catalog in Carrara.
is someone know the process ?
Thanks for the help :)
Jamy
    Do you mean icons in the Content area, Smart Content, or Scene/Objects/Shaders etc ?
    You can use the Large Preview/Small Preview buttons at the top of the pane at the bottom of the interface, but that is all that you can change as far as I know. The ones in Scenes/Objects etc, are saved a part of the .CAR files, and do not have a separate icon.
    The ones in the Content and Smart Content should have an associated .PNG file with the same name, and that can be changed to another image, but the size would remain the same as far as I know, is that what you mean?
  • JamyJamy Posts: 192
    Thank you for your answer Jimmy,
    it's exactly what I mean (sorry for my poor english). In fact, most of of the time when I save an object in "Scence/object…", the preview is not very good (not enough large). After that, it's very hard to find something. I'm disappointed to discover that there is nothing to do. :(
    I don't know of any way to change the size of the icons, other than the Small Preview/Large Preview, but someone else may be able to help. I haven't been using Carrara for very long.
    I know that there have been many requests to be able to change the font to a larger size as well, to make it easier to read.
  • PhilWPhilW Posts: 5,162
    edited September 2014
    The best way that I have found is to use a product called P3DO Explorer Pro. This allows you copy and paste in your own image, so you can frame your thumbnail exactly as you would like. It does lots of other things as well, but my own main use for it is in editing the thumbs for product releases. Note you need the Pro version, there is a free version but it doesn't have the thumb editing feature.
    http://www.senosoft.com/softp3dopro.php
    Post edited by PhilW on
  • JonstarkJonstark Posts: 2,738
    Yes, like Philw I also use P3DO (even though I'm not a vendor, It was worth it to me to save thumbnails I could easily visually identify for my various shaders etc)
  • ProPoseProPose Posts: 547
    I bought P3DO Explorer Pro a few months back for that very reason, but I have yet to use it. Is there a walk thru for that process somewhere out there?
    Yes Phil, I saw that, but if I don't make a mistake, it's only for PC, not for Mac.
    Looks like you are right, but it does say that it should work under a Windows emulation if that is any use to you. I am not aware of any other products that do this. Ringo recently posted a method which involves editing the .CAR file to change the shader:
    http://www.daz3d.com/forums/viewreply/667186/
  • Jay_NOLAJay_NOLA Posts: 1,145
    Tutorial P3DO Carrara video.
    http://www.youtube.com/watch?feature=player_embedded&v=Q1fisuxrOBQ
    I had this link in the plugins FAQ.
  • dot_batdot_bat Posts: 373
    if you are on a mac there is the develpoer pack that has an app for making icons http://support.apple.com/kb/HT5293?viewlocale=en_US&locale=en_US, you can try this. the last time i used it was for 10.6.8
    Must be getting old. I have that link. Thanks Jay
    Thank you Phil,
    I will try it asap.
    I don't know if I'm able to use it Dot_bat :/
    Not enough strong in using X11 or similar
  • Is P3DO still the best was to change thumbnails and does it run OK under Windows 10?
    Yes it does. 2.6.2 (August 2018) is the latest release as far as I know.
    Back up your .car file before you run it though, cos it can be a bit buggy, and it sometimes produces a file that then won't open.
  • rk66rk66 Posts: 449
    edited July 2019
    2.6 R2 update (September 28, 2018) is the latest.
    Post edited by rk66 on
  • Thanks guys, I had a look at the .cbr file and it seems to be an archive txt file with the image embedded as a byte array and I was thinking of having a go at programming Python to read the thumbnail which I think is housed between TVPr {...here...}
    i manually transfer thumbnails by copy pasting with notepad. (the byte arraysmiley)
    first i do a scene render to make the thumbnail i want. render with preview.
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited July 2019
    That's very interesting...
    Post edited by Persona Non Grata on
  • Well, I decided to purchase p3do and am waiting for a software key - how long does that take?
  • I'm still waiting...
  • Just arrived - so I'll give it a whirl...
  • Works a treat...
    (Click on detail above for the bigger picture)
    edited July 2019
    ..the only think I would say is that when you use the beautifully iconed shaders by either dragging them to the shaders tab or directly over an object Carrara recalculates the icon for the copied file - WHY???
    BECAUSE - any alterations to the shader need to be updated in the thumbnail - so, the developer decided to just program a sub-routine to do this automatically upon changes to the folder !!!
