Carrara Challenge #47: Structured/Unstructured...or "Unstructured Structure"
16781012
  • In your first illustration they are not all going under then over either (?) I don't have any wool to hand to plait and have a look see.
    Plait by Selinita
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,395
    Plait by Selinita
    Yeah not finding a good diagrammatic image I can share
    there are plenty but full of copyright terms
  • I've had a look and can see that the 3-ply plait has an X, Y frequence of, say 1 and a Y of 0.5 - I'll have a go...
    https://clipground.com/image-post/49064-plaiting-materials-clipart-17.jpg.html#overlayGallery_post_49064_plaiting-materials-clipart-17.jpg
    a better image but I best not embed it
    edited July 2019
    I made a plait curve brush for Zbrush but I used 3Dcheapscate’s mesh from shareCG as could not for trying do my own
    https://www.daz3d.com/forums/discussion/comment/4602341/#Comment_4602341
    Selinita said:
    That’s Carrara?
    Yes! Modelled and rendered in Carrara - no postwork or exterior renderer. Just pure, unadulterated Carrara!
    Really cool!
  • Is this it?
  • ..a better view
    NOTES:
    1. Start with a cylinder of 6 sides and 6 segments
    2. Duplicate and place directly on top and to the left or right so that from above the two form a figure 8
    3. Join points to form a spiral goes from one cylinder to the other
    4. Use this path to sweep a 6-sided shape of approximately one third size of original cylinder
    5. Smooth and join to form a ribbon of desired length.
    6. In Assembly room (if preferred) duplicate ribbon twice and place each copy one six down to form braid
    7. Squash and resize to suit desired result...
    Simples !
  • DiomedeDiomede Posts: 15,399
    Very impressive, Selina.
    edited July 2019
    I have three or four unfinished projects for this challenge.  Here is one.  Both Lego Emmit and Lego Lucy in the Assemble room.
    1563 x 826 - 159K
    Post edited by Diomede on
    Selinita said:
    ..a better view
    NOTES:
    Simples !
    yay I knew you could solve it heartheartheart
  • StezzaStezza Posts: 8,849
    loving your chainmesh ideas Selina ... very constructive and makes me wanna build a fence... in 3d of course yes
    I am having a bit of trouble following what to do though blush
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited July 2019
    Here you go...
    pdf
    pdf
    Plait-HOW-TO.pdf
    1014K
    Post edited by Persona Non Grata on
    Selinita said:
    Here you go...
    TY thats clearer now, I had no idea what bits were being selected without seeing cheeky
  • You're welcome - looking forward to your creations ...
  • Bunyip02Bunyip02 Posts: 9,285
    Thanks from me as well, been watching with interest !!!
    I really need to learn those keyboard shortcuts though, makes life easier
    edited July 2019
    well I chopped up a bit of the one I made and used it to create an inset mesh curve brush like before
    I must have set the 3 locks a tad out though as thats one mangey plait!
    yes can inflate more which hides much sin
    I wanted a loose one though too for embelishing things
    hair I can puff it up
    1920 x 1080 - 284K
  • DesertDudeDesertDude Posts: 1,239
    Selinita said:
    Here you go...
    Thank you Selinita - the techniques and images you have posted are really impressive! Mind boggling, actually. smiley
    ed3D said:
    Awesome ed3D - Yes!! Looks great!
    I especially like the details in the sand, those "waves"...I'm sure there is a technical term I don't know for that...Even though I live in the desert I live like 8 blocks from downtown Tucson, lol.
    Great to bring all those elements into Carrara. Bryce + Blender + Carrara. Yay!
    _ this is about  waves like those    _ +link below+ _  And again, Thanks
    https://www.scientificamerican.com/article/why-do-regular-wavelike-s/
    Thank you ed3D - very intertesting article. I'll have to read it a couple of more times to let it sink in.
    Those look...AWESOME Diomede!
    Very cool Wendy!
    edited July 2019
    Pondering an unstructured entry and was thinking of a basic scifi post catastrophe image.  How is this for irony, probably a very structured composition like a Frazetta or Hoffman sci-fi triangle for my unstructured image.  I put together a some quick elements.  To make the backdrop, I used a black/orange color gradient in the background, a relatively detailed foreground terrain, two less detailed distant terrains, some distant dark clouds, and a few twisted trees (use curve settings in branch edior) without leaves.  I rendered out the terrains/trees image.  I saved the terrain and lighting elements.  I started a new scene, reloaded the lights and foreground terrain, and inserted the first render as the background.  I reduced the resolution of the terrain, which is set as a shadow catcher.
    Rugged catastrophe survivors and their props yet to be added.
    1568 x 780 - 192K
    002 post apocalypse terain high def and lots of filters include plateau and zero edge.JPG
    1452 x 809 - 137K
    1588 x 796 - 179K
    1579 x 816 - 137K
    2400 x 1500 - 4M
  • VyusurVyusur Posts: 2,235
    edited July 2019
    “Ear Holder”
    Ear was modeled in Blender. Holder thing was modeled in Carrara. Screenshots are attached. Rendered with Octane plugin. No postwork.
    1300 x 1690 - 2M
    834 x 808 - 15K
    565 x 576 - 9K
    738 x 746 - 144K
    758 x 349 - 77K
    528 x 507 - 59K
    469 x 244 - 45K
    1217 x 673 - 314K
    864 x 796 - 44K
    558 x 801 - 59K
    232 x 191 - 6K
    452 x 297 - 35K
    604 x 521 - 47K
    625 x 505 - 48K
    537 x 489 - 37K
    806 x 833 - 221K
    1117 x 874 - 314K
    658 x 713 - 186K
    1022 x 816 - 288K
    846 x 922 - 71K
    881 x 970 - 318K
    876 x 886 - 279K
    863 x 1049 - 472K
    867 x 1052 - 460K
    Post edited by Vyusur on
  • ed3Ded3D Posts: 2,528
    edited July 2019
    + alright then      _  you're welcome +
    Post edited by ed3D on
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Vyusur said:
    “Ear Holder”
    Very creative and well-textured!
    still a few days for this.
    been caught up in eso. hit level 30
    Vyusur said:
    “Ear Holder”
    Thank you very much, UB, for your kind words and compliment!
