DS 4.11.0.383 & JoeQuick's Toon Hero for G8M & Hellboy's Flat Top hair for Genesis
nonesuch00nonesuch00 Posts: 18,830
edited July 2019 in The Commons
"Fit To" ran in an Infinite loop using JoeQuick's Toon Hero for G8M & Hellboy's Flat Top hair for Genesis. I stopped DAZ Studio over 2 hours later with the 'fit to' still running.
In addition I had already successfully fit to MEC4D's M5 Beard & Body hair product to Joe Quick's Toon Hero for G8M OK.
Has anyone tried this already & ran into the same problem? I am using DAZ Studio 4.11.0.383. I'm noticing more 'autofit fit to' problems with this newest version of DAZ Studio 4.11.0.... 366 ...383 and you get the ideal. The new DAZ Studio releases within the last 4 weeks.
Thanks.
Ciao
Post edited by nonesuch00 on
  • RawArtRawArt Posts: 6,146
    I dont make hair products, so likely was not me
  • nonesuch00nonesuch00 Posts: 18,830
    edited July 2019
    Oh, I thought you were Soto. OK, it is Hellboy. I guess I get you two mixed up.
    Anyway, this is the product, which is not at fault. At fault is DAZ Studio 4.11.0.383 and the way it's trying to create the 'fit to' information with the products in question.
    https://www.daz3d.com/flat-top-hair-for-genesis-and-genesis-2
  • HylasHylas Posts: 5,283
    I can confirm that it works in 4.10.
  • scorpioscorpio Posts: 8,533
    Thanks.
    Ciao
    DS 4.11.0.366 (the beta version)
    I didn't have any problems autofitting the Flat top hair unto the toon hero.
    Thanks, I figured it would. It used to work in the 4.11.0.2xx series of public betas as well. They've changed something with regards to autofit & the 'fitting-to' process in the 4.11 betas after 4.11.0.300+ and now many older products do not autofit correctly anymore.
    Maybe I need to to it the old fashioned way of fitting to original generation a product was designed for, then the succeeding generation, and so on until I get to Genesis 8 as I've bought that 'Wear Them All' product and it could be that is interfering with this new 'fit to' changes in the latest public betas.
    I'm working with a 4.11.0.3 version and as I said I didn't have a problem autofitting the hair - so it may be something else on your end.
