WIP Sci-Fi Starship Bridge
So I am currently working on a Starship Bridge. Here is the first render, will have more coming soon.
The Bridge will come with 2 different control panel stations, a standard chair a captians chair and of course a door that open and closes.
The command stations and the chairs are seperate objects so you can move them around anyway you like.
Any comments are most welcome. Thanks
«134
  • SBibbSBibb Posts: 601
    Looks nice. I like the dusty detailing on the edges of the windows, too. :-)
  • Thanks, its the first render. I'll send more when they are completed. :)
  • wizard1200wizard1200 Posts: 240
    The screenshot looks great. It would be nice if you could hide the consoles of the chair. Could you develop different rooms of the starship in the future? I ask, because it would be great to have a complete starship with the same look.
  • Do you mean like a panel cover on the consoles of the caprians chair?
  • So here are some more renders of the Bridge inside. I am planning on having a few different control screen panel presets to make some panels different if the artist likes.
    1100 x 688 - 173K
    1100 x 688 - 275K
    1100 x 688 - 266K
    1100 x 688 - 239K
    1100 x 688 - 167K
  • The screenshot looks great. It would be nice if you could hide the consoles of the chair. Could you develop different rooms of the starship in the future? I ask, because it would be great to have a complete starship with the same look.
    That is a great idea and I will look into it. :) thanks
    I mean the two 'pyramids' at the sides of the chair. A holographic display above the yellow object would be nice, too.
  • Good idea.
  • ok so here is the main captians chair. i did it so the side pieces are seperate objects that can be turned on or off. It was a good edit. :)
    720 x 480 - 265K
  • And here is the first render with the hologram. It was a great idea. thanks wizard1200
    1100 x 688 - 242K
    You are welcome.
    It would be nice if the pipes at the wall could be turned on and off, too.
    Nice additions with the hologram option and the ability to turn off the sides of the captain's chair. Both help add a nice degree of flexibility.
  • Ok so I did a little bit more detailing on the back wall, plus a created a material preset to turn on and off the wall pipes. :)
    720 x 480 - 304K
    720 x 480 - 295K
    The screenshots are amazing. I am looking forward to the release of the Starship Bridge.
  • Thanks :D
  • Ok so here are some final render. I wanted to add a few more details to the room. so here it is. :)
    720 x 480 - 133K
    720 x 480 - 136K
    720 x 480 - 158K
    Wow ... I hope that you will develop a Starship Cargo Hold, Starship Living Quarters, Starship Lab and a Starship Corridor :)
  • Those ThingsThose Things Posts: 1,175
    Oooh, and a med bay, dining hall, and shuttle bay!
  • :D sounds like fun and a lot of work but I'm up for it. :)
  • One question I have. Does anyone think there is a bit too much empty space in these images or not? I was thinking of creating a few filler objects. what do you all think?
    720 x 480 - 136K
    720 x 480 - 158K
    edited July 2019
    Yep, it looks a little empty. Additional (optional) objects are a very good idea.
    Would it be possible to change the texture of the central floor to look a little more metallic and less plastic?
    Would it be possible to add another hologram with enemy ships for example?
    Post edited by wizard1200 on
  • good ideas. :)
  • So this is what I changed so far and it looks much better. :)
    720 x 480 - 161K
    720 x 480 - 147K
    Yep, but perhaps it would be better to remove the grid around the chair, because sitting on top of an air shaft is probably not very comfortable :)
  • good point. but you can move the chair around but yea I should probably make the area a bit bigger for the chair. :)
  • Fae3DFae3D Posts: 2,927
    I really like the look of this, there's not too much going on with background clutter and it looks like there's actually room to move characters around.  The colors are good, too.
    I agree that the grid around the chair looks odd, but other than that this is really turning out very nice!  I've never bought a starship bridge before, but I would certainly consider this one!
  • I'm glad you all like it. :)
  • So I changed the floor to be more like glass plates. I think it looks better and it also shows off the pipes and other things that are inside the floor
    1000 x 1300 - 350K
    1000 x 1300 - 304K
    1000 x 1300 - 378K
    edited July 2019
    The Strarship Bridge looks great and using glass plates is a very good idea, because they offer a lot of options with the different transparency settings.
    Love this!
