How to put the tools tab back among the tabs? (Solved)
lukon100lukon100 Posts: 849
Among my tabs on the right side, I used to have one for the tools, under which I could find the joint editor. I reset my workspace and lost that. And when I select the joint editor from the tools menu, I don't see any control dials anywhere. So anyway, I want to know how to restore my tools tab again.
Answer I found: In the gray space between the tabs, right-click to get a menu. Click on "Add Pane" and then click on the tools item.
Post edited by lukon100 on
    Remember that you can saave a custom workspace layout. You can also drag panes to dock them where you want.
  • lukon100lukon100 Posts: 849
    My answer no longer works, at least for 4.11.
    Can someone please tell me how it is done for 4.11?
    Ok. I found the answer again. It is similar to the answer it used to be except it is more specific.
    Old answer I found: In the gray space between the tabs, right-click to get a menu. Click on "Add Pane" and then click on the tools item.
    New answer I found: In the gray space at the bottom of the tab strip (not merely the gray space between the tabs), right-click to get a menu. Click on "Add Pane" and then click on the tools item.
