Select surface covered by another surface
Hello,
Is there a way to select PART of the specific surface which is covered by another surface?
Here is few pictures to show you what I mean...
1 picture - top part of veil surface is covered by head surface
2 picture - if I want to select top part of veil surface I still select head surface even if it is hidden (opacity 0)
Question: How to select top part of veil surface??
I want to create new surface for this part and make it invisible (that is the easy part but how to select it??)
  • Richard HaseltineRichard Haseltine Posts: 108,764
    If you are using the Geometry Editor tool select the top layer, right-click>Geometry Visibilty>Hide Selected, then you can go on to work on the under layer.
