Teensy L.I.E. Tattoos: Download Size is 38 MB, Installed Size is 3.5 GB
Pixeluna's Teensy L.I.E. Tattoos for Genesis 3 and 8 is tiny in download size but huuuge on the hard drive, because every single PNG in the Runtime is 64 MB in size, except Teensy_TorsoALL.png, which is only 505 KB. I suspect that's not how it's supposed to be. I mean, what's the point in using a lossless picture compression format if the compression itself isn't used?
    You could try filing a support ticket, bearing in mind that it won't be picked up till Monday at earliest.
