[Released] RSSY Hair Converter from Victoria 4 to Genesis 8 Female [Commercial]
245678
  • carrie58carrie58 Posts: 4,076
    edited June 2019
    HR2  files are supposed to work with it just FYI.  Sayuri hair is one of them that does not convert , one of many ! Also Kelp Hair , Adhafera , Lotus Hair , Cece Veil Hair , Fox Hair , Alrisha......
    Okay I have Adhafera ,Kelp and CeCe Veil Hair and they converted fine ,@Timotheus those are from Rendo and I don't have them to test .
    But again I am doing "Add Files and converting only 2 or 3 at a time and changing the conformer to match the hair ,and so far they are all converting ....
    2000 x 2000 - 4M
    Post edited by carrie58 on
    edited June 2019
    3anson said:
    @carrie58  tried 7 hairs by SAV, none recognized ( Goldy, Dynasty , AlphaMoikana etc )
    @3anson Okay lemme see if I have any of SAV's hairs , yup I have 2 and one thing is SAV has both a Cr2 and a prop  the Cr2 coverts fine here is Aphana Hair by SAV
    2000 x 2000 - 7M
  • RiverSoft ArtRiverSoft Art Posts: 6,778
    edited June 2019
    Wow!  A lot of messages.  I apologize if I don't address any.  The metadata for V4 hair is... poor.  A LOT of the hair, you will have to select (not just checkmark) and use the Force Convert button.  The regular Convert button looks at the metadata.  When the metadata is poor, you will see the SKIPPING "" file message.  Between the quotes should be the metadata the script sees.  If nothing is there, or weird stuff like wardrobe, the regular convert button will skip it.
    If after adding, force convert doesn't work (or you can't add even using "Add Files..." with the Check Content Type option off), please repost.
    Thanks.
    Post edited by RiverSoft Art on
    Oh, and HR2 files should work too (though I won't guarantee all of them)
  • DkgooseDkgoose Posts: 1,451
    edited June 2019
    Apparently with 4.11 anytime I try to save a morph or anything it now fails, is there a way without reinstalling poser to transfer the fit morph for v4 to the converted hair?
    Edit : Figured it out :)
    Post edited by Dkgoose on
  • 3anson3anson Posts: 314
    okies, another PA gave me the tip to select the actual hair file, instead of the wrapping folder, and that has worked 90% of the time for me.
    i have now successfully converted some of my favourite V4 hairs, iz a happy bunny now!
    ( btw, i use *Force Convert* all the time after using the various converters for a while :))  )
    @RiverSoftArt     95% of the .hr2 files i tried converted successfully, and the bonus was most were also 'non-attended' ( ie, the weightmap choice widget rarely popped up)   smileysmileyyes
  • pde1965pde1965 Posts: 7
    With The Exception Of The Conversion Morphs,The Other Morphs That Come With The Hairs Do Not Show Up.
    What was the issue?
    I am glad it is working now for you.
    I did like that about the hr2 files smiley
    That is strange.  They should be transferring.
    What was the issue?
    Somehow the authorship information in preferences for changes to a bunch of wacky symbols so once I went and changed that it let me save stuff again,  how it happened I have no clue though lol
    What was the issue?
    Huh.  Another upgrade issue I guess.
  • TimotheusTimotheus Posts: 249
    I went back through and double-checked my settings very carefully. Could have sworn I had disabled Check Content Type, but I had not. Now that I can add files to the list, Force Convert works. Thanks for another great converter!
  • ArtiniArtini Posts: 10,287
    edited June 2019
    Converted Greek Fantasy hair by Studio Art Vartanian on Sydney 8 - https://www.daz3d.com/sydney-8
    1000 x 1200 - 342K
    Post edited by Artini on
    edited June 2019
    Hr-117 hair by Ali on Sydney 8:
    1000 x 1200 - 301K
  • Nyghtfall3DNyghtfall3D Posts: 812
    Unless there's a solution to the problem outlined below, I blew $13 on a product that is now useless to me.
    There is only one V4 hair in my collection that I have any interest in converting:  https://www.daz3d.com/violet-hair-for-v4
    I tried loading it into your script and it couldn't find the hair's cr2 file.  It returned an error telling me no hair files could be found.
    Your PDF says the converter needs a Charadcter or Hair directory in the path.  The Violet hair already has a default Character directory.  I tried creating a Hair directory and moved the hair there but no dice.  Trying to add the directtory path and/or cr2 file both report an error claiming no hair files were detected.
    I examined the Options tab in your script and everything relevant is checked.
    Quick trial, it’s V3 hair and clothes
    800 x 1000 - 2M
  • OdaaOdaa Posts: 1,548
    edited June 2019
    It's possible that Riversoft can offer some further guidance on this, but if not, please take advantage of the 30-day return policy.
    Post edited by Odaa on
    edited June 2019
    Converted Violet hair for V4 on Genesis 8 Female
    and after applying https://www.daz3d.com/rssy-3delight-to-iray-converter to hair materials
    cr2 file is located in Poser mapped directory under:
    Runtime\libraries\Character\VioletHair
    1280 x 1080 - 153K
    1280 x 1080 - 191K
    1280 x 1080 - 171K
    1261 x 523 - 151K
    edited June 2019
    Converted SAV Alpha Moikana by StudioArtVartanian on Genesis 8 Female
    1280 x 1080 - 187K
    1280 x 1080 - 239K
    1280 x 1080 - 201K
    edited June 2019
    Converted SAV Athena hair by StudioArtVartanian on Genesis 8 Female:
    1280 x 1080 - 268K
    1280 x 1080 - 247K
    edited June 2019
    Converted SAV Aram Hair by StudioArtVartanian
    and with shaders from https://www.daz3d.com/backlight--hair-shaders-for-iray-
    and another one from shaders https://www.daz3d.com/alchemy-for-backlight-hair-shaders-for-iray
    1280 x 1080 - 219K
    1280 x 1080 - 260K
    1280 x 1080 - 221K
    1280 x 1080 - 273K
    1280 x 1080 - 252K
    1280 x 1080 - 341K
    So.  We know it works.  Good.  Now all I have to do is figure out what I'm doing wrong.
    Thank you.
    edited June 2019
    pde1965 said:
    Post edited by pde1965 on
    edited June 2019
    Converted Fox Hair - V4 on Genesis 8 Female - https://www.daz3d.com/fox-hair-v4
    and with hair shaders from Backlight - https://www.daz3d.com/backlight--hair-shaders-for-iray-
    1280 x 1080 - 226K
    1280 x 1080 - 227K
    1280 x 1080 - 226K
    1280 x 1080 - 215K
    edited June 2019
    Converted DragonBraid - https://www.daz3d.com/the-dragonbraid-for-victoria-4
    with its addon - https://www.daz3d.com/the-dragonbraid-addon-tails
    on Genesis 8 Female. Hair and addon materials converted with: https://www.daz3d.com/rssy-3delight-to-iray-converter
    1280 x 1080 - 204K
    800 x 1200 - 133K
    edited June 2019
    ... and with different sets of materials.
    800 x 1200 - 213K
    800 x 1200 - 125K
    edited June 2019
    Converted Fox Hair - https://www.daz3d.com/fox-hair - on Genesis 8 Female.
    Hair materials converted with https://www.daz3d.com/rssy-3delight-to-iray-converter
    960 x 1200 - 213K
    960 x 1200 - 190K
    960 x 1200 - 282K
    edited June 2019
    Converted Drake Hair - https://www.daz3d.com/drakehair - on Genesis 8 Female.
    1920 x 1200 - 413K
    1920 x 1200 - 418K
    1920 x 1200 - 467K
