Anyone else having problems with this web site
PippenPippen Posts: 265
edited June 2019 in The Commons
I'm trying to buy Urban Future 6. It says it's in my cart but when I click on the cart, it says it's empty. I've logged in and out. Closed my browser and tried again. I'm fed up. If I could curse, I'd let them have it. No money for Stonemason and Daz.
Post edited by Cris Palomino on
  • TykeyStudiosTykeyStudios Posts: 867
    Just tested and it's working for me. I tested all the way through the checkout process before I submit payment.
  • FSMCDesignsFSMCDesigns Posts: 12,845
    Works fine for me also. Did you try a different browser?
  • HavosHavos Posts: 5,597
    Often for these type of errors the solution is to add a second item, and then the cart will show 2 items, not as empty. You can then delete the second item you added.
  • Drogo NazhurDrogo Nazhur Posts: 1,268
    Not to hi-jack this thread but where are the settings to see the price history of a package? I've never seen that feature before.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,227
    the DAZ Deals browser Addon
  • 3Diva3Diva Posts: 11,981
    You can download the Daz Deals Add-On here: https://www.daz3d.com/forums/discussion/106296/announcing-daz-deals-browser-add-on/p1
    I HIGHLY recommend it to anyone who shops at Daz - it's a HUGE help with a lot of great features. :)
    I had this very problem the other day. The only way to clear it is to add something else to the cart and then hit the clear the cart button. Then you're good to go. Only happens to me sporadically.
    Laurie
  • mwokeemwokee Posts: 1,275
    Sometimes I have to add a random item which resets the cart then I remove it from the cart.
  • P A Y A T   PP A Y A T P Posts: 1,177
    Shopping has been so hard these days. Glitches, incompetent website algorithm, financial constraints, missed discounted sales, incompetent coupon, and so on and so forth.
  • ironclawxiiironclawxii Posts: 172
    Add a second item to the cart. Or open a different tab with the same item on display in there. Check your cart, if it's empty, add it again and it will work. It's not that hard.
  • Doc AcmeDoc Acme Posts: 1,153
    I've addopted the practice where after I've added an item, I CLOSE that window instead of clicking Continue Shopping.
    The Continue Shopping link is what's boogered.
  • James_HJames_H Posts: 1,091
    Related but different: the 'Clear the Cart' button used to empty the cart, but that doesn't seem to work for me any more. Does it work for others?
  • xyer0xyer0 Posts: 6,347
    Clear Cart works for me.
  • No !
    Works fine for me,  and I use it regularly when have loaded a cart up just to check what other people are having problems with
