Age of Armour Advanced Ambient Lights and Spotlight - issues with 4.11?
Ptrope
in The Commons
I just upgraded to 4.11, and just bought these light sets on sale, but their installations fail with every attempt. I'm not seeing where I can find the reason for the failures, in IM - are there any known issues with these light sets and 4.11? Do they require a specific installation path? I'm not installing Daz content on my C: drive.
Those products install shaders and scripts to the DAZ Studio program folders. Do you have the proper path set for 32- and 64-bit software in the Installation tab of Install Manager settings? They are usually C:/Program FIles (x86) and C:/Program Files, respectively.
I have the paths set for where I prefer the software be installed; my other scripts and shaders installed and work fine from that.
I'll just manually unzip the data to the correct location.
Check the DIM log and DIM Helper log. The regular log file shows mainly startup and content installation, and the Helper log shows plugins. Ctrl-Click on the Show log button to get the Helper log file (there is a tool tip that shows up if you hover the mouse long enough over the button).
Oh, yeah, make sure Studio is not running when you install them.
