Iray makes Daz Studio 4.11/Windows crash
2»
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,963
    edited June 2019
    Did you test if it crashes disabling the card and using CPU?
    because if it does the issues are not related to your card or driver
    it could be your RAM
    I had to replace a stick of RAM a couple years ago because rendering was crashing my computer with Bluescreens
  • Noah LGPNoah LGP Posts: 2,617
    edited June 2019
    Only CPU works.
    CPU + GPU doesn't work, nvlddmkm crash.
    Windows 10 Memory Diagnostic Tool (mdsched.exe) find no error.
    Post edited by Noah LGP on
  • Same here, still looking for a sollution...
  • kenshaw011267kenshaw011267 Posts: 3,805
    Noah LGP said:
    Only CPU works.
    Did you check your page file settings and how much space is available on the drive that has it?
  • algovincianalgovincian Posts: 2,687
    Creator driver is only relevant if you use one of the specific pieces of software it is optimized for. DS isn't one.
    Available today, the newest NVIDIA Studio Driver provides optimal support for the latest releases of top creative apps, including Autodesk Maya 2019, 3ds Max 2020, Arnold 5.3.1.0, Blackmagic Design DaVinci Resolve 16, and Daz 3D Daz Studio.
    https://www.nvidia.com/en-us/geforce/news/nvidia-studio-driver-now-supercharge-your-favorite-creative-apps/
    - Greg
  • rogerooorogerooo Posts: 5
    Just tried the Studio version of the 430.86 drivers (removed old ones) with no apparent improvements whatsoever. Crash to black screen with just a couple of G8 figures with hair and some clothing, nothing too demanding in terms of power and memory I believe. CPU rendering is painfully slow but works, switching to GPU it doesn't even render the first iteration. I must say that I'm only using 8gb of ram and that might be a bit low for more demanding scenes but I've rendered stuff more complex than a couple of figures in the past with no issues on this setup.
    edited June 2019
    I too am getting crashing, I will try the studio driver and see if it works. My scene is simple. Two characters and sun and sky lights. Rendered before with no issues. I have 32 gig of ram and the nvidia game driver. I am thinking of returning to 4.10 I hope I saved the installer.
  • In case it helps anyone, I have been having same problem with DS 4.11
    pc 64 bit
    intel core i5 cpu 750 @2.67 GHz 266 GHz
    windows 7
    16 gb ram
    GeForce GTX 970
    driver (d/l from nvidia) 430.86
    Error logs mention OptiX, turning OptiX Prime Acceleration (in the adanced settings tab) off has stopped the majority of the crashing though it still freezes and gets slow as molases often. If your error log looks similar you can try, as a way of getting by until it's fixed
    2019-06-07 22:31:40.340 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(301): Iray ERROR - module:category(IRAY:RENDER):   1.4   IRAY   rend error: OptiX Prime error (Device rtpModelUpdate BL): Memory allocation failed (Function "_rtpModelUpdate" caught exception: Encountered a CUDA error: cudaMalloc(&ptr, size) returned (2): out of memory)
    2019-06-07 22:31:40.387 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(301): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 970): Scene setup failed
    2019-06-07 22:31:40.387 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(301): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 970): Device failed while rendering
    2019-06-07 22:31:40.387 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(301): Iray WARNING - module:category(IRAY:RENDER):   1.2   IRAY   rend warn : All available GPUs failed.
    2019-06-07 22:31:40.403 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(301): Iray WARNING - module:category(IRAY:RENDER):   1.2   IRAY   rend warn : No devices activated. Enabling CPU fallback.
    2019-06-07 22:31:40.403 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(301): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: All workers failed: aborting render
    2019-06-07 22:33:16.717 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(301): Iray WARNING - module:category(POST:RENDER):   1.0   POST   rend warn : renderer iray has no more devices available. Postprocessing falling back to CPU.
    2019-06-07 22:33:16.998 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Available GPU memory has increased since out-of-memory failure. Re-enable CUDA device 0.
    Thanks for sharing that info. Indeed turning OptiX off helps, it still feels quite unstable but the graphics driver crash seems to be less frequent. Hopefully someone finds a way to properly fix the issue with OptiX working again.
    edited June 2019
    Finally I found Daz Studio 4.10.0.107 installer, now it works.
  • Iray crashes for me too since some time and i am realy wondering why. It crashes on szenes I coul render probably before without any problems.
    So what is going on? What changed and why I cannot use Iray anymore?
  • PadonePadone Posts: 4,187
    In my opinion it looks like the new nvidia drivers are not working fine with 9xx cards. And since 4.11 requires new drivers your only option seems to go back to 4.10. Disabling Optix and/or using the studio drivers may improve the new drivers reliability though.
    At least in my case, I disagree. I'm using 418.81 with my 980TI without problems. People seem to forget that the "latest" Nvidia drivers are not always without problems. People having trouble with the latest Nvidia driver should just try rolling back a few editions. New Nvidia updates are often released to accommodate a recent game and won't have any impact on rendering with DAZ.
    There are seems to be a great number of people that did not read Studio release notes to see the minimum Nvidia driver requirement.
    edited June 2019
    @fastbike1 I tried Daz Studio 4.11 + 418.81, it still crash.
    @Padone there is no Studio driver for GeForce 9xx and in my case it's worse when OptiX is disabled
    edited June 2019
    @fastbike1 Another thing that may make the difference with the same driver release is the version of windows. Those with win 7 or win 8 or a different version of win 10 may be dfferently affected.
    EDIT. It would be nice if the daz team would publish the exact version of windows and of the drivers they test 4.11 with, so to at least have a reference. In the 4.11 discussions I only found "recent drivers are recommended".
    Post edited by Padone on
    It's not just the 9xx cards. My card is a 1070 with 430.86 drivers on windows 10 and I'm crashing too. Haven't tried older drivers to rule that out but yes, it's possible that Nvidia broke Daz with the latest update.
    Are you guys using the post denoiser? Might be that it messes with iray at somepoint and just crashes it?
  • edited August 2019
    I tried different drivers, installed the current driver 436.02 and it was still crashing. The solution was easy, I spanned over two partitions the windows paging file and fixed them to a certain size. The first pagefile is 20 gig and the second one is 50 gig. I have a HP Z800 system with 32 gigs of ram with a nividia 1060 6 gig video card using windows 7 pro. Try playing around with the pagefile in windows. Just my two cents.
    Post edited by aszwec_8e481a0934 on
