Hardware devices to control parameters
I would like to use some external hardware device such as an xbox controller or AKAI midi slider to be assigned to DAZ 3D parameters (such as tranlate parameters)
I cannot find anything on this through my searches, and "controllers" seems to mean something else in the DAZ context.
Unity allows me to write code to control a game object. Is there a similar object that can be manipulated in daz script?
If there is, then an example script would be a great starting point.
TIA
  • ConnaticConnatic Posts: 295
    Maybe mCasual has written such a script.  Look in freebies forum section for his posts.  He has sites with an amazing amount of scripts and other creations.
  • Silver DolphinSilver Dolphin Posts: 1,656
    TIA
    Sounds like an interesting idea but most people will just use the sliders or enter numbers for changes. You could send in a support ticket and ask for this to be a new feature. They might listen.
  • a_s_lorda_s_lord Posts: 33
    Thanks for the ref. Lots of good stuff on that site. The midi keyboardist might give insight, but I have not found precicely what Im looking for there yet.
    TIA
    It might help if I elaborate the idea a bit.
    I'm looking to pose a figure using some external device quickly in comparison to some image (put on a reference plane surface).
    I want to tweak an assignable set of properties such as bend, twist, side-to-side, for such as lower neck, upper neck and head, and the reference image opacity.
    I can click through to these parameters and play with the values, but the number of iterations needed to get it right impedes the process.
    Instead, I would prefer to use some hardware device that allows me to twiddle with the parameters intuitivly.
    Something like the Korg NanoKontrol offers hope (although it only has 8 sliders) whereby I could assign lower neck to the first three sliders and so on or whatever. XBox controller is another option.
    Its unlikely that a script exists, but I could attempt to write one, so it would be helpful if there was any info on how to read a value from such a device, and apply it to a chosen parameter.
    KORG - Korg NanoKontrol 2 MIDI Controller (black)
  • CybersoxCybersox Posts: 10,038
    There was a company in Japan (e-frontier?) that briefly made a full human shaped Digital Input Device that could control a Poser type figure, so the basic process can be done.  That said, I think DID development has really dropped off since mo-cap got so cheap with the kinnect and the leap.
  • Syrus_DanteSyrus_Dante Posts: 983
    Maybe this is what you are looking for:
  • JhudJhud Posts: 36
    Wonder if MJCasual will update the mcjHIDKit script to work with the Logitech G13 GamePad.
