"Snap!"
LeatherGryphon
I'm looking for a towel model that I can use as a weapon... as in a locker room scene where the towel is used as an improvised whip to "snap" a victim on the bum during horseplay.
Help!
I use DAZ Studio 3 (not 4 unless absolutely necessary)
Any ideas?
I can't think of one off the top of my head for DS3... but thinking outside the box, there might be some hair ponytails/braids that could be retextured and posed with built-in movement morphs.
If you adjusted the x or y of a morphable sheet and modded the tip with dform I bet you could get something.
Post work is probably gonna' have to happen either way.
Thank you.
I did select a few things to experiment with (Roman cloak, magic carpet, morphing sheet, etc.). None are yet completely satisfactory but by tweaking, overriding limits, D-Forming, retexturing, and patience I might find something that looks OK from one particular direction.
There's a towel that can be held in the 'Towel set for Genesis' which should work in DS3 as they're not the newer duf files used in ds4.
a quick twist with a ds magnet should make it more 'Snappy' looking
http://www.daz3d.com/towel-set-for-genesis
The prop towel will work best. I don't think it has any swing morphs, but you could d-form it to have a bend in the middle, I'd think.
