DAZ 4.6.1.17 can´t export OBJ files to Lightwave 11
jaxtonejaxtone Posts: 73
Strange enough this all happend after I bought me a new PC with Windows 7 Professionsl and a 64 bit OS before I installed DAZ Studio 4.6.1.17 and Lightwave 11.5.1 and Lightwave 11.6.
Why did DAZ change the software so the OBJ export functions doesn´t work properly anymore?
Solutions? Explanations? Magicians?
    AFAIK DS will still export an obj file.
  • fixmypcmikefixmypcmike Posts: 19,718
    Are you unable to find the option, or does the export fail or work differently than you expect?
  • jaxtonejaxtone Posts: 73
    ... the export fails and works differently than earlier versions of DAZ?
  • frank0314frank0314 Posts: 14,869
    How does it fail? What does it do?
    Lightwave can´t open these files any longer, before the latest DAZ update everything worked perfect!
    Does this happen with any object you export from DS< even something simple or that you've exported before? Are your export settings the same?
  • Richard HaseltineRichard Haseltine Posts: 110,390
    Please post screenshots showing the steps, from File>Export in DS to whatever happens (or fails to happen) in LW. Your description isn't clear - are you getting errors?
  • edited December 1969
    Are you able to open the converted OBJs in Accutrans3D? There, you can convert them in LWO.
  • MattymanxMattymanx Posts: 7,000
    I would also suggest posting screen shots of your export settings in DAZ Studio
    As MCMXC has mentioned, AccuTrans3D can convert the OBJ to a LWO as can DeepExploration but AccuTrans3D is far cheaper ($20 USD)
