Anilip 2, how do I make a word end in a question mark?
3dGordon
Greetings,
I am using Anilip 2 successfully, so far, but want to make the last word go up in tone for a question mark: "are you happy?"
Is this possible?
Thanks! Gordon
Which voice do you use? There should be a difference in pronounciation between 'Did you hear that' and 'Did you hear that?'
Otherweise try the SSML 'prosody' element.
<speak version="1.0" xmlns="https://www.w3.org/2001/10/synthesis"
xml:lang="en-US">
<s>
Did you hear <prosody pitch="x-high">that</prosody>?.
</s>
</speak>
You can do much more with 'prosody' and find more infos here.
Best Regards
Dobit
OK: (ascend at the end)
United States TTS Engine:
Ivona 2 Ivy OEM US Female
Ivona 2 Salli OEM US Female
Not OK:
Microsoft David
Microsoft Zira
Cepstral Robin - over 5 years old?
Cepstral Amy - over 5 years old?
Prosody looks like learning a foriegn language. Do you think it would work on the old Cepstral voices?
I will look into more of the OEM Voices, are there other companies that might work?
Great software, once you get past the wrapping.
We get the pitch ascend for David and Zira as well. You use WIndows 10?
Dont't know about Cepstral. We tested their demo and it seems to ignore the question mark. But may be the SAPI versions work better.
Amazon Polly voices work quite well with punctuations as ? or even !,.
