Is there a script to copy the diffuse parameter into ambient?
Is there a script to copy the diffuse parameter (both the image and the color) into the ambient parameter for a selected surface?  It's not hard, but annoying to do manually when there's a zillion materials already in use to search through.
  • HibernatusHibernatus Posts: 19
    Well, I would like a script that copies the bump image to the diffuse channel, as I like to create high-contrast b&w images...
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    edited June 2019
    This does a lot of things, but includes copying images from one channel to another, even across multiple surfaces and objects. I use this a lot, particularly when changing from one shader to another. I do believe it only does images though, don't think I've looked for a setting for the color. https://www.daz3d.com/map-manager
    Post edited by AlmightyQUEST on
    Thank you so much! That seems to be what I was looking for.
