Meet the OddBods. 4 toon style Halloween monsters.
mrsparkymrsparky Posts: 249
edited December 1969 in Freebies
PP2 format. No moving parts, These are low-mid poly weight models with 1024*1024 textures (2 per model) designed for use as quick scene fillers.
Included in the set is Sid the Skelly, Vlad the Vampire, Frankie, and the mystery Yawn of the Slightly Undead!
Textures are in .BMP format rather than .JPG to preserve detail, so studio and users of other apps may need to convert to JPG before using.
Note: the models had vertexes spilt in UVmapper at the default angle of 43 degree. Sometimes this can results in parts of a model appearing to darken in some areas when rendering. The effect can also appear when using some light sets . If this happens try adjusting the smoothing angle in your 3d app, or playing around with the OBJ in UVmapper. This is NOT a fault, it just sometimes happens when modeling spherical things in Carrara 5 and with UVMapper.
Download from... http://www.sparkyworld.co.uk/3d10own.htm
