View port stays empty i can´t see any model i want to open
Hello,
i just jumped into the very complex but fascinating world of photorealistic 3D rendering and began experimenting with the free samples given. I suddenly missclicked and now each time i open DAZ3D and open up a new file, to start creating a new 3 model well....there is nothing. Nothing shows up, may it be a structure, a body, clothes, accessoires, creatures... I simply don´t see anything.
Even trying to open a saved creation doesn´t work since the center view port stays empty. Even the tutorial doesn´t work since the view port is gray.....i´m lost Help T-T ....
Thanks...
Is the Viewport pane actually there? I suspect you may have closed it. You can reopen it from Window>Panes(Tabs)>Viewport and drag it into place by its top bar, or you can just use Window>Workspace>Select Layout to reload your workspace.
