[HELP] Only one of three models in bundle contained metadata!
I downloaded the 'The Good, The Bad, And The Ugly' bundle which contained a donkey, hippo, and bison model. Only the donkey shows up in my smart content section. The other two don't have checkmarks in the install window (I've redownloaded and reinstalled them several times to change this but it didn't work). I can access the two models in the content library section, but I have to apply the texture map manually each time after loading the base model. It would be more convenient if they just showed up in my smart content tab like the donkey does.
Does anyone know how to fix this? The guides on this site for missing models had odd verbiage and/or outdated instructions and thus were not helpful.
  • NorthOf45NorthOf45 Posts: 5,756
    Many older products do not have any metadata, so you will have to add it yourself. Here is a good tutorial showing how to do it. It's getting a little old, but I don't think the process has changed much. There are probably several other threads out there with similar information.
