Rendering by zones/diffuse/id materials
MaloneXIMaloneXI Posts: 187
Hi all ,
I'm acheiving my comic book after about one year of work \o/
For now , the first volume has been classified "secret" , because it's for my bro's birthday :) So , I wanted to acheive this one so it could be a true object of discussions , art direction , dialogs etc.
Well , I did many tries to have an homogenic art direction. It's my first comic book , so it's extremly difficult to get satisfaction. I wanted to have something close to the halftone process that belongs to manga , with a mix of 3D, outlines , etc.
So I tried many shaders , many tutos I've found on the web. Sometimes, like for "manga shaders", that was too late... I would have had to prepare all my models with this shader , but the delay was too short and I took it too late, the project was too advanced.
Here is an example (my question is coming , I just want to explain in details, to be the clearer as possible) of what I did for a first try.
I rendered the scene with "Graphic Art cameras" halftone process. And next , I rendered the outlines with tooncam, and assembled in photoshop.
Maybe my halftone is a bit bigger, but I'm not quite sure it's the main poblem lol , now I would want to select zones and reboot the look with a more manga look-alike, based on gradients , etc.
And , now , my question : Is there a meaning to render only zones , as a depth map , or this kind of things ? Is there some kind of process to only obtain delimited color mass that could help me selecting zones easier than If I do it with hand-selecting.
I'm not sure if I am clear.
I want to render all the diffuse maps as color zones so I could select them to redesign the look with specific gradients , etc.
Could somebody help ?  Thanx a lot.
*edit : I've found an example of what I'm talking about :
Is something like that possible ?
Post edited by MaloneXI on
  • Richard HaseltineRichard Haseltine Posts: 110,497
    In Iray you can use the Canvasses sub-tab of the Advanced tab of render Settings to set up various ID passes.
  • MaloneXIMaloneXI Posts: 187
    Yep I've found this tip on otther posts. I'll give a try . For now , I'm using the multipâss toolbox from Dragoonstorm. But not friendly to uinderstand lol
    Thanx a lot !
