full anemone gives duplicate IDs, remove script doesn't work
even when I load the full Anemone for Genesis 2 Females, after I save the file, it loads with duplicate IDs. so that's the first bug. when I try to run the remove duplicate ID script, the script fails to run. I've attached the error from the dump. any ideas on what I'm doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 109,541
    Sounds as if the actual file may be corrupt - though I'd expect that to fail to load in DS, rather than to give a Duplicate IDs error. Will it actually load the content after the Duplicate IDs error, or is that it?
  • alxalx Posts: 53
    it works as expected, although it may be increasing the render time. would you recommend that I just overinstall the content?
    You could try, though if it's working I am probably wrong about the corrupt file (depending on which file might be corrupt)
