full anemone gives duplicate IDs, remove script doesn't work
even when I load the full Anemone for Genesis 2 Females, after I save the file, it loads with duplicate IDs. so that's the first bug. when I try to run the remove duplicate ID script, the script fails to run. I've attached the error from the dump. any ideas on what I'm doing wrong?
txt
txt
dupfil.txt
2K
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Sounds as if the actual file may be corrupt - though I'd expect that to fail to load in DS, rather than to give a Duplicate IDs error. Will it actually load the content after the Duplicate IDs error, or is that it?
  • alxalx Posts: 53
    it works as expected, although it may be increasing the render time. would you recommend that I just overinstall the content?
    You could try, though if it's working I am probably wrong about the corrupt file (depending on which file might be corrupt)
