Poser/DS compatible product?
http://www.daz3d.com/shop/warraok-kitt/
Just curious if this is compatible with Poser/DS, almost went to purchase it and it only says Bryce, however http://www.daz3d.com/shop/licorne/ is the complete opposite, but the style/render of the promo images look nearly identical, was just wondering before I commit to something that I shouldn't.
The Warraok Kitt is clearly Bryce only. The Licorne says Daz Studio, Poser under Compatible 3D software. You can do a lot in either program with a sky dome and a water plane.
I know it says Bryce only, but between the two products, they look like they were rendered in the same program, which sucks 'cause I really wanted the Warraok
Both are by the same PA. They do very good work, I also wish BOTH were for DS.
Edit to add they might have been Rendered in Bryce by use of the Daz to Bryce bridge.
perhaps we should make a request of the artist to make them compatible? :D
That's probably an error, I've never heard of Faveral doing Bryce items. The readme on this product clearly shows pp2 (Poser) files, so it can be loaded very well into DS, you just need to adjust surfaces.
